Question about Zanussi TD4100W Electric Dryer
Zanussi tumble dryer td113w noh producing hot air
hards327
  • 30 Answers
SOURCE: Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Posted on Mar 17, 2008
  • 17 Answers
SOURCE: zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Posted on Dec 18, 2008
  • 86 Answers
SOURCE: zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Posted on Feb 09, 2009
michaelcanto
  • 76 Answers
SOURCE: dryer is tumbling but air is cold on TD62 zanussi
is this gas or electric?
Posted on Jul 28, 2009
heatman101
  • 43501 Answers
SOURCE: I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 20, 2010
Tumble dryer does not produce hot air on hot mode, do I need a new heater element?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Zanussi Dryers
I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT SEEMS FINE, THERMO ALSO FINE BUT STILL NO HOT AIR BEEING CIRCULATED
heatman101
Aug 20, 2010 | Zanussi TC7114W Electric Dryer
My tumble dryer ois not heating ?
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
this could be the stats or the drum is not turning Common faults -
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Cold air
It seems that it is more likely a Burned Out Heating Element.
Check and let me know if the problem still persists.
Hope i helped you.
Thanks for using " Fixya " and have a nice day!!
Jul 11, 2009 | Zanussi TD4112W Electric Dryer
No hot air is being produced from my Zanussi TC 180 condenser dry
what make is it?is it a top lint screen or inside?
Mar 31, 2009 | Dryers
Zanussi tumble dryer does not get very hot
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Zanussi TD4100W Electric Dryer Logo
24 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
