Question about Tablets & eReaders
My tablet hp estation zeen turn off and i can't turn it back on
I was using my tablet and i ran out of battery and when i plug it in it didn't turn on. i didn't have the original charger and i bought one from steren shop( it did'nt work very good) i need to know how can i turn it back on
Gort007
  • 1187 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Posted on Sep 03, 2009
  • 5 Answers
online shopping
Posted on Mar 08, 2012
  • 36 Answers
SOURCE: Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Posted on Apr 05, 2012
sands_darren
SOURCE: My Android tablet was on the charger charging, and
u have 2 options 1 is to get the tablet reflashed or the most common problem is that u have overcharged the battery and it will need a new one this problem is very common in tablets as opposed to i pads as the tablets only get the bottom market parts where as the ipads get higher quality components
Posted on May 16, 2012
  • 4961 Answers
SOURCE: My acer charger got wet, I thought I dryed it off
You could go to the place you bought it or another tech store and see if they have another tablet like yours lying around so you could test out and see if it is just your power cord that needs to be replaced. Because most likely it's time to buy a new power cord. Hopefully you didn't fry the tablet's motherboard also that's why you should test out the power cord first.
Posted on May 29, 2012
My tablet went out and won't cut back on and my battery not dead
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
www.tomsguide.com/forum/id-1869519/tablet-turn.html
Oct 17, 2015 - 50 posts - ‎43 authors
I was charging my tablet overnight because it was dead and when I woke up in the ... I plugged the battery back in...snapped the rear cover back on, .... My Samsung Galaxy 3 (7.0) ran out of battery completely - I followed this ... my rca tablet won't turn on I tried charging but it's not ...
Dec 15, 2015
my polaroid tablet won't turn on - Tablets
Jun 20, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
samsung tablet wont turn on - Samsung
Sep 17, 2014
More results from www.tomsguide.com
Dec 21, 2015 | Tablets & eReaders
Xtouch tablet won't turn on
let it cool down and it will eventually work ;)
May 20, 2013 | Tablets & eReaders
Touchpad wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 25, 2012 | HP Touch Pad 16GB Internet Tablet
Have a white screen on tablet can' turn off nor on pandigital
Very gently unplug the battery cable for two minutes.. I used a pair of tweezers and worked it out. Plugged it back in and it is fine. What a relief. I have read that if it goes to sleep while plugged in via usb, it freezes? Don't know. Just be careful when pulling the battery!
Jun 25, 2012 | PANDIGITAL Tablets & eReaders
Was playing a game on tablet and screen went white and still white for the past 12 hr.
Very gently unplug the battery cable for two minutes. I used a pair of tweezers and worked it out. Plugged it back in and it is fine. What a relief. I have read that if it goes to sleep while plugged in via usb, it freezes? Don't know. Just be careful when pulling the battery!
My hp tablet has a battery with a question mark an will not turn on
i think that your tablet's battery must be a duplicate.you an go to the HP office and complaint about it, they would repair or replace the battery!
Nov 30, 2011 | Tablets & eReaders
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Oct 16, 2011 | Archos ARNOVA 10 Android Tablet
The battery completely drained and now I have it plugged in to the computer via a usb cord but I am not sure it is charging at all. How can I tell?
Well the screen will Turn on but like mine it drained and I hadn't been on it for a while and then I plugged it in and it didn't turn on but I Just left it and then it fired to Life !! I hope this Helped x
Jun 07, 2011 | Archos 28 Internet Tablet
Tablets & eReaders Logo
55 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
