Question about Xerox WorkCentre Pro 123 Copier
Fault code 047-216 for xerox workcentre pro 123
Fault code 047-216
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 2072 Answers
SOURCE: I have Xerox workcentre pro
That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
Posted on Jan 28, 2009
Xerographic
  • 5 Answers
SOURCE: I have Copycentre 123. I
You need the extra 256K memory board to make this work. It's standard memroy if I recall.
Posted on Mar 26, 2010
  • 17 Answers
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Posted on Apr 03, 2010
  • 31 Answers
SOURCE: le code erreur j7 pour
change le drum cartridge
Posted on Feb 03, 2011
Jam inxerox workcentre pro 128 copier finisher stapl area
how do i repair a staple jam in my xerox workcentre 128?
Jan 15, 2013 | Xerox WorkCentre Pro 123/128 Copier...
Xerox WorkCentre Pro 123 linux driver ?
if you open your web browser, put in
www.xerox.co.uk, go to cusomer support then to suport and driver,
there put
  • WorkCentre M123/M128 and then your operating system. From there you should find the driver package for the linux system
Dec 06, 2017 | Xerox WorkCentre Pro 123/128 Printer
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
Error 116-364
Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
I have Xerox workcentre pro 128 copier machine. can you solve my problem? when i copy before appear this Error code 123-396.
Jan 28, 2009 | Xerox WorkCentre PRO 128 Copier
Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Sep 08, 2008 | Office Equipment & Supplies
Xerox WorkCentre Pro 123 Copier Logo
986 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
