CONNECT A HTV-SW1 PIONEER SUBWOOFER TO A SR880 MARANTZ AUDIO RECIEVER
  • 13433 Answers
SOURCE: connecting Pioneer VSX-816 Reciever to SONY DVR player
Here is the owners manual
http://www.manualnguide.com/dl/6004/
see section 4 for connecting
Posted on Jun 08, 2008
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
  • 118 Answers
SOURCE: cannot get jamo 250 subwoofer to work via marantz
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Posted on Nov 04, 2009
jdvillanueva
  • 2098 Answers
SOURCE: how to connect my computer
here the steps:
1. locate the earphone jack on your pc.
2. after finding the earphone jack from your pc you need a connector (baby stereo plug to 2xrca plug).
3.connect the baby stereo plug to your earphone jack and then the rca plug to your Pioneer axuliary in.
Posted on Jan 02, 2011
dunnbiker
  • 8546 Answers
SOURCE: No signal going to my
First, did it EVER work?
No? Review the speaker setup in the receiver and make sure it knows you have a sub and is sending LFE to it.
Yes? Feed it a signal directly from a CD player or something. Start with a quiet sound passage as you probably will have no control of the volume.
If you need help beyond this, name the sub and how it's connected.
Posted on Jan 18, 2011
I HAVE A MARANTZ SR880. WHEN I SWITCH IT ON, IT STAYS ON STANDBY MODE. WHEN I SELECT INPUT, IT CLICKS AND THE STANDBY LIGHT FLICKERS. WHAT DO I NEED TO DO?
Possibilities for dry soldering. its a Common problem with this model. Also can happen because of aging . Its tedous procees to open and repair the av receivers. Its better to find expert who can do it for you. i think Marantz authorized service center will not do this as its an out dated model .
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Feb 18, 2015 | Marantz Audio Players & Recorders
Hook up a pioneer htv sw1 to a receiver without the other parts
Not sure what you are doing here or what kinds of connection are available.
Aug 31, 2012 | Pioneer HTV-1 Shelf System
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Trying to hook-up a turntable to sr880. which input works best? also think the receiver is muted, how do i unmute the system?
Is it Marantz???? The Marantz 880 doesn't have an input for PHONO. A traditional turntable will require a PHONO preamp between it and any Line Level input on the receiver.
Muted? Look at the front panel for clues. Maybe sure no tapes or unattached inputs are selected. Try the test tones to prove it works.
Mar 27, 2011 | Audio Players & Recorders
Hi can I hook up my marantz mm500u amp to my pioneer 305 vsx audio reciever
I presume you just want to slave the Marantz to play whatever the Pioneer is playing.
Run a pair of RCA cables from either the Pioneer Tape Monitor REC or the VCR/Tape 1 Out jacks to the desired Marantz Input jacks. DON'T activate the corresponding switch on the Pioneer.
Only the basic Leftand Right channel programming that the Pioneer plays will be available at the Marantz. You will NOT have centralized volume control at the Pioneer.
Mar 17, 2011 | Audio Players & Recorders
I want to connect my Marantz 1030 amp to a yamaha YST-SW012
use the left input on the sub. It acts as the main input. Hope this helps
Nov 19, 2009 | Car Audio & Video
Trying to connect powered subwoofer
Try setting the speaker settings on the receiver to small.
Jan 12, 2009 | Pioneer VSX-D511 Receiver
Hook up for pioneer htv c1
To hook up to tv you have to make sure your tv has a (audio out) port then use rca cables and hook up to (audio In) port in the back.
Jan 01, 2009 | Pioneer HTV-1 Shelf System
I have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.When i plug everything in and power it up i get a quick 3 second burst of sound and then it stops,but the...
i have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.Lost the cables, can somebody help me, dont know where to get them???......original cable part # are
ADX-7239 this is the system cable A and (rectangle connector)
ADE-7023 this is the subwoofer cable B.....(round connector) 8 pins both
is there any compatible cable....thanx apprecieate ur help!!!
Jun 30, 2008 | Audio Players & Recorders
20 people viewed this question
 Grubhead
Grubhead
