Question about Microwave Ovens
Resetting Panasonic genius 1100W microwave after power cut
I have lost user manual and need to reset microwave after a power cut.
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic 1100W high power
It may have a blown fuse or - assuming yours is a model NN-H965 - a defective inverter. The fuse is generally located on the bottom of the chassis of the microwave. You have to remove the outer cover on a counter top model - or the front panel assembly on an over-the-range model. There are several reasons why it may blow. If the fuse is loose in the holder, the fuse and the holder should both be replaced. If - with the microwave disconnected from the wall - you can easily turn the fuse with your fingers while it's in the holder, then it's too loose. What happens is the loose connection generates too much heat, causing it to melt internally. If so, you'll usually see a ball of solder at a point where the cap meets the body of the fuse. If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. You can find my files "doorsw.txt" and "safety'txt" via Google. They give you the safety warnings and cover the diagnosis and replacement of the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. They offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number. Be safe!
Posted on Oct 14, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Genius 800w locked
On many models, you press "Stop / Reset" three times.
A hard reset may help: Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can probably download it (or one that's very close) here:
http://panasonic.co.uk/customer-Support/download-centre.asp
If that doesn't work, you can contact Panasonic UK at http://panasonic.co.uk/customer-Support/svc-dealer-locator.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC NNC753BBPQ DIMENSION 4 800W MICROWAVE
You will find that here.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
SOURCE: we had a power blackout now my panasonic genius
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
Posted on Oct 08, 2009
Panasonic genius 1100w inverter microwave stops after 23secs.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here:
Support Panasonic
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Panasonic Microwave Ovens
Cant open door on panasonic genius 1100w
One of the door opening parts has failed, most likely the lever or the door open button.
See this safety information and these disassembly instructions.
You will need to take the outer cover off the oven, then you can see the door opening parts.
As you try to make the door open, you can see the mechanism and which piece has failed.
You can order Panasonic microwave parts from Encompass here, and for other brands, see this parts ordering page.
For more free DIY and other help & advice, feel free to contact me directly.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* (on the tag in cooking cavity or around door frame or control frame or on back)
pupista@gmail.com
Jan 29, 2017 | Panasonic Microwave Ovens
Panasonic Inverter Genius 1100W NN-ST7805. How do I replace the light?
Depending upon the design, it may be necessary to remove the outer cover to gain access to the light for replacement.
May 21, 2015 | Panasonic Microwave Ovens
I have a digital genius microwave---how do i set the clock PLEASE?
Are you try checking your Panasonic User Manual ? (zip file)
Hope helps (remember to rate this answer).
Jun 24, 2011 | Panasonic NN-T888S Convection/Microwave...
Please could you tell me how to set the timer on an old Panasonic Genius microwave - Model NE 691. Thank you!
I suggtes visit this link to download the PANASONIC/NE691-User manual
Just click some "stars" and comment something like a "cool" word and download now!
Gooe luck.
Feb 22, 2011 | Panasonic NN-T888S Convection/Microwave...
Hi, I have lost my user manuel for my Panasonic (The Genius) NN-S676WA , Where can I find a copy so I can set the time. Thank you
quick setup guide:
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
operating instructionsl:
http://service.us.panasonic.com/OPERMANPDF/NNS659.PDF
Feb 21, 2011 | Panasonic NN-S676WA Microwave Oven
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 14, 2008 | Panasonic Microwave Ovens
User guide for Panasonic Genius NE 691 600Watt
Click here to download the user's guide.
Let me know if you need further assistance.
Sep 05, 2008 | Panasonic NN-T888S Convection/Microwave...
New Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
Aug 24, 2008 | Panasonic NN-P295SF Microwave Oven
Microwave Ovens Logo
134 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
