Question about Sewing Machines
My dog foot wasnt raising on my singer 7466 touch and sew. So i took the outer casing off in the process i found a black pin like part floating around. I have no idea where it goes. How do i get the diagram of my internal part components? I have a manual that shows noting about the inside of my sewing machine and where parts belong.
    President:
  • 2,692 Answers
Contact the manufactor of you brand of sewing machine and ask for a illistrated parts drawing.
Posted on Jan 12, 2009
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
Nov 30, 2017 | Singer Sewing Machines
Singer 7466 opening plastic case?
you can remove the rocker switch this will allow you to move the case away which inturn will allow more access
Sep 05, 2008 | Singer 7466 Mechanical Sewing Machine
Even on the raised setting, the feed dogs won't move the thinnest summer weight fabric. Does anyone know how to fix this problem on the Singer Model #7426?
Could be the presser foot is not applying enough pressure to the feed dogs. Check your owner manual for instructions on increasing the presser foot pressure. Could also be that the feed dog height needs to be adjusted or their teeth are worn (do not run the machine without fabric between the presser foot and feed dogs).
Aug 22, 2017 | Singer Sewing Machines
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
I have a singer touch & see sewing machine, I need to change for quilting but there are no visible switches to lower the metal times under the foot.CAN ANYONE HELP I'M ON A DEAD LINE. THANKS,
I don't know this machine but in most machines the feed dogs are normally lowered from a switch beside the bobbin case behind the door of the bobbin case.
Jun 14, 2015 | Singer Sewing Machines
Pressure foot lever is loose, is there a way to fix without taking it in for repair shop?
open he face and check the clamp screw. If loose raise foot to give 5/16" clearance and retighten after ensuring foot is in line with feed dogs slots
Feb 18, 2014 | Singer 5062 Mechanical Sewing Machine
Feed dogs will not raise, I have lifted the presser foot, pushed the feed dog lever to the raised positon and turned the handwheel till i heard the click. They still will not snap into place in the raissed...
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Apr 16, 2011 | Singer 7436 - INGENUITY
I have a 7466 Singer sewing machine. No matter how I adjust the thread tension, the top thread always pulls the bobbin thread through to the top. I am doing thread painting. The feed dogs are lowered and...
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Mar 28, 2010 | Singer 7466 Mechanical Sewing Machine
Feed dogs on Singer 7466 wont stay up.
There is a screw behind the feed dog with a plastic nut ,you need to loosen the nut and move the screw up or down and retighten where needed,,,,,,,,,also there is a plastic support under that screw that could have come out of place ,which means you will have to open the machine to reinstall it.
Sep 01, 2008 | Singer 7466 Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
