Question about Sony Ericsson Cell Phones
Sony xperia ion emergency call only even sim card is inserted
  • 11 Answers
SOURCE: INSERT SIM
It might be that there is some corrosion on the leads that connect to the SIM card. You can try using a soft pencil eraser on the leads to see if you can clean them up, being careful not to get any debris from it in the phone to avoid any future strange complications.
Posted on Jun 19, 2007
SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
Posted on Nov 21, 2007
SOURCE: Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Posted on May 04, 2008
  • 4102 Answers
SOURCE: How do I transfer my contacts from sim card to new
hi do this
press menu
then phone book
then options
then copy
all
sim to phone
ok
that should then copy them for you
let me know if you have problems
Posted on Sep 24, 2010
hellosanj21
  • 95 Answers
SOURCE: how do i copy contacts
phone book pe jao option select karo copy to sim ok karo all contact ok karo dushra phone pe eesi sim ko lagaoo aapne aap so hoga
Posted on Feb 16, 2011
WHEN i RESTARTED MY XPERIA i ONLY GET EMERGENCY CALLS ONLY. i THEN PRESS THE START BUTTON AND WHEN MY SCREEN COMES UP FOR MY PASSWORD AFTER I KEY THAT IN IT GOES TO EMERGENCY CALLS ONLY.
G'day Joan, I don't know, so until someone can help I would reset the phone try holding the three buttons in for 10 seconds (I do that on my phone) or until something comes up on the screen follow prompts. Cheers Greg.
Jun 10, 2016 | Sony Ericsson Experia X8
Sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
Sony st21i stuck on emergancy calls only
if the sim card is not active on the phone network it will only allow emergency calls check if you have service with network provider.
Apr 14, 2014 | Sony 1264-0775 Xperia Tipo Dual ST21A2...
I need to know the proper insertion of the Micro SIM for my Xperia P
The SIM card has gold plated contacts, place the SIM card with the contacts so the line up with the contacts on the cell phone.
Dec 07, 2012 | Sony Mobile 1261-4445 Xperia P Lt22i Smart...
Sony lt15i insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Oct 19, 2012 | Sony Ericsson Xperia Arc Xperia Arc LT15i...
How to unlock the software of Sony ericsson Xperia
You need to Unlock your sony ericsson phone from network lock to use with other GSM Network Sim card...Without Unlocking you can't use with other GSM Network Sim card.Get the unlock code from the site
Onlinegsmunlock.com/unlock-your-phone/rs7wp2/ and unlock it easily...............
Jul 27, 2012 | Sony Ericsson Xperia Arc
Sony xperia says faulty sim card and sim not provisioned
Try to insert another SIM card and check if the problem persist, if yes then there is some problem wiith your set.
Else, if other SIM is working then there will be some problem in the SIM which has got blocked for some reasons.
Get in touch with the service provide to get a new SIM for nominal charges.
Hope this works for your.
Pls take your time and let me know if I was able to help you.
Richee
Jun 10, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Can anyone help. How can I unlock my Sony Ericsson X8 which is on Vodaphone Ireland. Thanks in advance.
Instructions Unlocking Instructions for Sony Ericsson XPERIA X8
How to insert the Unlock CODE into your Sony Ericsson XPERIA X8
  1. Power ON your Sony Ericsson XPERIA X8 with an accepted SIM Card.
  2. Press the LEFT arrow or joystick button once.
  3. Press the STAR (*) button twice.
  4. Press the LEFT arrow or joystick button again.
  5. You will briefly see one of the following messages listed on your Sony Ericsson XPERIA X8 display:
    • Personalized with MNC2
    • Personalized with MNC3
  6. Wait approximately 4 seconds.
  7. The display will indicate "Network" and a picture of a closed padlock.
  8. Press Select.
  9. The display will indicate "Unlock (Net) 5" and "NCK:"
  10. You can now enter the Unlock CODE supplied by UnlockallCellular.com.
  11. Your Sony Ericsson XPERIA X8 will display "Network unlocked" and then "Insert SIM" message.
  12. Your Sony Ericsson XPERIA X8 is now unlocked!
If your Sony Ericsson XPERIA X8has a Joystick (for example SonyEricsson K700i), then you must press the DOWN Arrow instead of the LEFT Arrow for step 3 & 5. By DOWN Arrow I mean directing the Joystick down!
Feb 14, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I HAV A SONY XPERIA X10 MINI PRO and when i insert my sim card the phone does not start but if i remove the sim it starts
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockspot.com/sony-ericsson-xperia-x10-mini/rs10wp9/
Jan 18, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Cell Phones Logo
282 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
