HOW TO CONNECT MY HTV-SW1 PIONEER SUBWOOFER TO MY MARANTZ RECIEVER
5 Suggested Answers
  • 13433 Answers
SOURCE: connecting Pioneer VSX-816 Reciever to SONY DVR player
Here is the owners manual
http://www.manualnguide.com/dl/6004/
see section 4 for connecting
Posted on Jun 08, 2008
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: No signal going to my
First, did it EVER work?
No? Review the speaker setup in the receiver and make sure it knows you have a sub and is sending LFE to it.
Yes? Feed it a signal directly from a CD player or something. Start with a quiet sound passage as you probably will have no control of the volume.
If you need help beyond this, name the sub and how it's connected.
Posted on Jan 18, 2011
SOURCE: I have a Pioneer HTV-C2
i have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.Lost the cables, can somebody help me, dont know where to get them???......original cable part # are
ADX-7239 this is the system cable A and (rectangle connector)
ADE-7023 this is the subwoofer cable B.....(round connector) 8 pins both
is there any compatible cable....thanx apprecieate ur help!!!
Posted on Jun 03, 2011
Connecting Marantz Power amp to Marantz reciever
Please see my answers regarding the hookup of Marantz amps and preamps.
Feb 21, 2014 | Marantz MM7025 Amplifier
Hook up a pioneer htv sw1 to a receiver without the other parts
Not sure what you are doing here or what kinds of connection are available.
Aug 31, 2012 | Pioneer HTV-1 Shelf System
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Hi can I hook up my marantz mm500u amp to my pioneer 305 vsx audio reciever
I presume you just want to slave the Marantz to play whatever the Pioneer is playing.
Run a pair of RCA cables from either the Pioneer Tape Monitor REC or the VCR/Tape 1 Out jacks to the desired Marantz Input jacks. DON'T activate the corresponding switch on the Pioneer.
Only the basic Leftand Right channel programming that the Pioneer plays will be available at the Marantz. You will NOT have centralized volume control at the Pioneer.
Mar 17, 2011 | Audio Players & Recorders
Remote for Pioneer HTV-2 not working
I never did fix the remote, but I was able to use my other remote (universal) to control the Pioneer HTV-2. Thanks
Jun 04, 2009 | Pioneer HTV-2 System
Trying to connect powered subwoofer
Try setting the speaker settings on the receiver to small.
Jan 12, 2009 | Pioneer VSX-D511 Receiver
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
I have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.When i plug everything in and power it up i get a quick 3 second burst of sound and then it stops,but the...
Jun 30, 2008 | Audio Players & Recorders
1974 marantz model 2325 reciever and want to hook up a powered subwoofer ?
Hi jdwoomer
BEST WAY
Your amp has PreOut and Main In RCA connectors on the rear, you could make up an adaptor cable (or buy one) to split the post vol control signal at this point, and then use line level from here to drive the sub.
OR
Most powered subs have a speaker "high level" input, where the sub "sniffs" off signal from your speaker output. When setup like this the speakers and amp connect to the back of the Sub.
Either way, you can do it... Marantz were making nice gear back then... a collectable these days :) Any questions, I am here to help.
regards
robotek
May 06, 2008 | Marantz PM7200 2-Channel Amplifier
How to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
Dec 27, 2007 | Velodyne DPS-12 Subwoofer
94 people viewed this question
 Grubhead
Grubhead
