Question about GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12...
I have a GE Monogram under counter beverage fridge. It has a large chunk of ice built up on the back wall. Otherwise, it keeps drinks cold and seems to run fine. Is there an issue, or does this typically occur?
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Posted on Jul 29, 2008
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
tborn6
  • 700 Answers
SOURCE: GE Model GSH22JFTA Top of Fridg and Freezer not cold
check the door gaskets for air leakage
Posted on May 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE TFX20SA back wall of freezer freezing (snow
CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
Posted on Jul 13, 2009
woodchuck789
  • 4066 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
Ge fridge not getting cold - pds22sfsarss
If this is a new fridge and you installed it make sure all of the shipping plugs are removed.
Sep 25, 2013 | Refrigerators
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Need to replace my ZISB42DCA should I go with latest Monogram or a comparable Profile or switch to Kitchenaide. We have had a lot of problems with this one but it came with the house.
I have a 42" GE monogram refrig: ZISB420DMC. Water dispenser has had all kinds of problems and I've already had it fixed once. Same for ice dispenser. I just get ice directly out of the bin rather than have it dispense ice. This refrig also doesn't seem to have very much storage space. I can't even put a large pot in the refrig because of that silly light in the back of the refrigerator. I don't like GE refrigerators anymore. I've seen friends and family buy the Samsung refrigerators. They are really nice and I would get a Samsung. Here in Hawaii, Lowes seemed to have the best prices on the Samsung refrigerators.
Aug 17, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Fridge and Freezer are Warm Ice is still being made
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Apr 17, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12... Logo
27 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
