Question about Sony 900mhz Baby Monitor
Monitor just started to have a high pitched loud static and two of the lights stay lit. Just started tonight. Sony 900mhz babycall
Monitor worked fine last night. Now it has a load static sound and at least 2 lights stay lit. I've tried to change channels and have yet to find a combination that works. Both monitors act the same, is it the base? Any help is appreciated.
SOURCE: Sony Explode 4 channel amp in protection mode
sometimes if the power cable and the ground cable are frayed and touch it will short out the amp temporarily check to make sure allof the wires aren't touching each other
Posted on Aug 14, 2007
SOURCE: Sony Bravia KDL-40S2000 40 inch
We have the same problem.. Checked the Sony site after a few clicks got to: http://www.iq.sony.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=966,E=0000000000761838071,K=1708,Sxi=1,Case=obj(460991),VARSET_OBJ=460991,VARSET_TSRC=results,UseTemplate=case.tem,VARSET_TOP=TRUE
We followed the 'simple' troubleshooting tips then called the service center. As mentioned above 4 blinks indicates a bad panel. The repairman that visited said that he is ordering a new power supply (much cheaper than the back panel) for their first try. I will post again when my set is back on.
Posted on Dec 22, 2007
  • 4 Answers
SOURCE: sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Posted on Jan 01, 2009
    SOURCE: Sony PS-LX300USB Turntable, one channel not working
    Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
    If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
    Posted on Apr 19, 2009
    Geekman
    • 32281 Answers
    SOURCE: sony vaio vgn nr160e laptop - no display
    You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
    To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
    The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
    Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
    www.ladparts.net
    Posted on Oct 20, 2009
    It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
    Samsung LCD TV with no video and high pitched sound - Digital TV ...
    www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
    Jan 7, 2010 - 26 posts - ‎15 authors
    Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
    Samsung LCD Green Screen - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
    Jun 11, 2015
    Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
    Jun 11, 2015
    Samsung DLP crackling/static noise
    Jun 11, 2015
    LCD TV making clicking/cracking sounds
    Nov 24, 2006
    More results from www.cnet.com
    Samsung LCD Loud Noise and Green Vertical lines at Start up ...
    www.badcaps.net > ... > Troubleshooting TVs and Video Sources
    Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
    Loud high pitch noise
    The noise could be from the fly-back transformer.
    There are very high and dangerous voltages inside a CRT monitor.
    As you are not an electronics technician, I suggest you do not try to fix it yourself, your eyeballs will light up if you poke your fingers in a wrong spot.
    Get a quote for the repair, but the cost of monitors these days are fairly cheap and a repair may not be a cost effective solution. Consider getting a LCD monitor, they take up less room and they are very energy efficient.
    Oct 28, 2009 | Apple Mitsubishi Diamond Pro 2060u 22" CRT...
    Monitor Goes black, or flickers on and off
    The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
    Check out LCD parts for parts, service and DIY info. use this link :-
    www.lcdparts.net
    Aug 29, 2009 | ViewSonic OptiQuest Monitor
    There is a loud buzzing/static sound coming from my monitor. It changes pitch and sound a little with different screens. The visual display does not seem to be effected. Just a terrible sound. Any ideas...
    Start by getting a can of the electronics spray air and blowing out and areas that may collect dust.
    Also jiggle the power cord attached to the monitor and watch to see if it changes the monitor or the squealing at all.
    Seems more like a lose power connection, but eliminate the simple possibilities before moving toward circuit board issues etc.
    Also do you have any other high powered electronic devices near the monitor?
    That can effect it's performance as well.
    Jul 23, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
    Suddenly making loud static noise
    I have a dect 6.0 cordless phone and all of a sudden it started making this very loud, high pitched continuous whisltling sound. It only stopped when I took the batteries out. After putting them in the phone seems fine now.
    Any ideas what happened?
    Jun 28, 2009 | Uniden Cordless Phone
    The Transistor H.O.T maybe shorted , Get a technician to have a check.
    Jun 07, 2009 | Televison & Video
    Refrig shut off and will not restart - light bulbs still working
    this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
    Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    CRT color moitor
    The "terrable loud high pitch sound" could be the horz. oscillator.
    The voltages off the crt should be (+) (-) 11v to 15v DC. Too much on Blue & Red guns will cut them off
    Jun 21, 2008 | Televison & Video
    Sony 900mhz Baby Monitor Logo
    48 people viewed this question
    Top Sony Baby Gear Experts
    Dorel UK
    Dorel UK
    Jennifer Rock
    Jennifer Rock
    Are you a Sony Baby Gear Expert? Answer questions, earn points and help others
