Question about Yamaha RX-V690 Receiver
Volume Control Failure on Yamaha RX-V690 receiver.
I have lost the volume control on my receiver. It shows the text on the screen when I press the volume up and volume down buttons on the remote but the knob doesn't move. I can manually lower the volume by turning the knob. My guess, after removing the knob, is that there is a motor that turns the knob and hopefully a repairable peice. This is an excellent receiver that I'd rather not part with. Any suggestions on how to fix this issue?
  • phaduman Jan 16, 2009
    that is the exact same problem I have on my RX-V995. Have been resorting to manually turning the knob by hand. But would really like to fix the issue. My guess is the same as yours, volume knob motor is failing. Anyone has a service manual?
petraman7
  • 1175 Answers
SOURCE: Yamaha RX-V690 powers up and turns right off??????
Hi...
All the speakers are connected at both ends?
If so, you have a power amp electrical break.
Not an easy fix.
Posted on Jan 14, 2009
  • 33 Answers
SOURCE: no sound, volume knob is blinking
On the bottom of the remote on right side, right next to the master volume - key . it is actually called muting instead of just mute. Hope this helps.
Posted on May 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX V690 keeps shutting
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 03, 2011
dunnbiker
  • 8546 Answers
SOURCE: How would you connect the yamaha YST-SW015 to the
Follow the manuals for it... http://www.retrevo.com/support/Yamaha-YST-SW015-Subwoofers-manual/id/320ag324/t/2/
... and the RX-V690, page 11.
Posted on Aug 01, 2011
SOURCE: Yamaha RX-V1000 volume control erratic, remote
Hi.
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
It's not much but I hope this helps.
D
Posted on Aug 21, 2011
Balance control
The channel that is weak will either have a faulty transistor or a bad capacitor on it. Most engineers would test it by injecting signals into the circuit at different points. Working backwards from the front end. When the signal goes weak, you have found the faulty stage.
Jul 02, 2017 | Yamaha RX-V690 Receiver
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
I have a Yamaha AX-V690 receiver but I do not have a remote control. Can I buy remote for this unit oris there a universal remote I can use? Thank you. Plz reply to: molly@prtc.net. Thks.
You can purchase a remote for it if you would like. The part number for that remote is: VS713700 You could also use a universal remote if you would like. But keep in mind that most of the inexpensive universal remotes only support the major functions such as Volume, Tune Channel, etc.
http://www.remoteyard.com/yamaha-vs71370-vs713700-rx-v90-rxv90-rxv900-rx-v900-en.html
This is a replacement, but this particular remote is pretty expensive, and you could probably get a nice universal for that price (the lowest I found it was $69.95). Good luck, hope I have helped!
Mar 03, 2011 | Yamaha RX-V690 Receiver
Dear Sirs, I have a Yamaha Rx- v363 receiver 2008 yr. model. I'm looking for help in programing the volume control on this unit. When I turn the unit off and then back on the volume it stuck on its highest...
Page 48 under Set Menu:
Initial volume INI.VOL.
Use this feature to set the volume level when the power of this unit is turned on.
Choices: Off, -80 dB to +16 dB
Control step: 1 dB
Feb 20, 2011 | Yamaha RX-V363 Receiver
Volume control
This is an option that is generally available from your TV set. Sony, Sanyo and others have it. It may be called differently by its owner, but it's most likey available from your TV's menu settings.
One probable name could be AVC (Auto Volume Control). Good luck!
Aug 17, 2009 | Yamaha RX-V690 Receiver
The volume knob is flashing red on my AX-SD1 amp..no sound.
Unplug the receiver, let it sit for a minute or two then plug it back in. It's either in "mute" or in Protection. Generally, Yamaha's will say "Ck. Spkrs" If it still has a problem, post a comment and I will look up some sources and help some more.
Aug 07, 2009 | Yamaha RX-V690 Receiver
No sound, volume knob is blinking
May 05, 2009 | Yamaha RX-V690 Receiver
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V690 Receiver Logo
159 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
