Question about Whirlpool GEW9250 Electric Dryer
Had been using my dryer all day and on one of the last loads it just stopped heating so now I have wet clothes. The dryer kept running through the cycle, the time kept going down and everything else seemed to be working fine. Not sure of the model as I can't find that any place and I think it is like 3-4 years old
  • 101 Answers
Most likely your problem isn't the vent as you were using it all day. Without hooking up a volt meter to the parts on the dryer though it is hard to determine. Most likely though the problem is the thermal fuse. It's common for this to go out on electric dryers and it is cheap and easy to repair. If the thermal fuse goes out then the heating element won't stay on for more then a second or two. This can go bad for a number of reasons but usually happens because your vents aren't allowing enough air to exit. It's probably not to stopped up but it may be enough to have caused this to happen. The thermal fuse is located usually near the heating element housing and is a small looking fuse with two different colored wires attached to it. It is no more than an inch or so long and is fairly skinny. There is a wire diagram located behind the control panel backing. Just remove the few screws and you will see it. Just make sure to put it back for any techs that ever come out to service it. You can get a thermal fuse at any local appliance repair store for around 15 dollars and it only takes about 15 minutes to fix it. I hope this information helps you out and if you have any other questions let me know. Good luck.
Posted on Jan 22, 2009
  • 82 Answers
If your vent is stopped up with lent your limit switch will trip and stop heating. you could have fusable link or even bad heating elements.
Posted on Jan 12, 2009
No heat for my frigidare fex831cs top load stacked washer dryer
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Feb 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Okay my dryer has been popping the CB for the last three days, I through it was the two thermostat's were replaced. Ran the dryer ops checked normal, now when I put a load of wet clothes in it runs for...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I garee with you about the motor, but it also could be the heating element heating up and shorting out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 09, 2010 | Hotpoint NVL333EY Electric Dryer
My daughter in put a load of wet clothes (not completely finished spin cycle). Now dryer doesn't heat the clothes but seems to have all other functions.
Try running the dryer empty to see if the elements are heating. With the weight of wet clothes it is possible to trip the overloads.
Jan 03, 2010 | Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 16, 2009 | LG DLE7177 Dryer
Old Kenmore Dryer Stopped Blowing Heat
either the heating element is out or the limit switches are out one or the other
Jan 24, 2009 | Kenmore 62602 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
