Question about Sharp Microwave Ovens
Sharp microwave r-428jk will not heat food
Turns on fine will not heat
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Feb 08, 2009
bestdarngood
  • 3037 Answers
SOURCE: it turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
ginko
  • 19396 Answers
SOURCE: Samsung Microwave runs won't heat
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Sharp - Food not heating up but all is lit up and turn table turns
Hai my friend, if its not heating you must open it at the back and check your fuse on top for contuinity using amultimeter it must be on abuzzer and if its fine there is other fuse covered with normal black cover connected to the cspacitor also check it, if this two fuses are fine check your capacitor if its fine check your magnetron for contunuity of 0,2 ohms but normal if its not heating its fuse, thx
Sep 13, 2014 | Sharp R959SLMA 900 Watts Convection /...
I have a sharp over the range convection microwave modelr-1874F The convection works but the microwave sounds like it working, the turntable turns but it does not heat the food we tried unplugging it for...
Every time the microwave part of an oven do not heat it normaly means a faulty MAGNETRON (the device that produces microwves) unfortunately if it's the magnetron they are allmost as expensive as the oven it self, you could allways check for a burned fuse, (allways be prudent opening an applyance)
Jan 04, 2011 | Sharp R-1874 Convection/Microwave Oven
My sharp r-340f works for 10 seconds, then turns off, then turns on again but with the countdown timer not counting down. Moreover, no microwave radiation comes out. Thus, the food is still cold after...
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 23, 2010 | Sharp R-340 Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Regarding microwave
Sanjay
This is due to the magnatron failing (this is the part of oven that cooks the food!) This is the most likely cause of y isssour oven not heating the food!
Magnatron needs replaced for oven to work again!
Please rate this free soultion!
Jan 18, 2009 | Sharp R-308J Microwave Oven
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Jan 15, 2009 | Sharp R-1481B Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave works fine, but wont heat food....
I would say the high voltage rectifier diode has blown.
See http://www.gallawa.com/microtech/diode.html for help in diagnosis.
Okay, now that I see the model number, that's a US model:
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Sep 22, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
