Question about Garden
2.5hp kamodo yardmaster edger
Need a fuel tank
2 Suggested Answers
moretons
  • 155 Answers
SOURCE: The fuel lines have rotted out of the edger gas
no you can buy replacement fuel line but you must reconnect the filter in the tank that line goes to the bottom of the carby then out the top of the carby to the inlet on the primer then out of the primer and back to the tank.
Posted on Jul 25, 2009
On an unidentified trimmer/edger, How does the gas line run between the carb., fuel tank, and purging bulb?
Hi Galligher:
fuel line typically goes
- from tank out (this is the one that has the filter inside the tank end) to carb inlet.
- from carb out to bulb suction
- from bulb out back to tank.
Cheerfuls
Feb 07, 2016 | Garden
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
what does the manual tell you about engine oil
Nov 24, 2015 | Garden
Which of the 2 fuel lines on PE550 edger is the steady fuel line for constant running?
Trace the hoses down into the fuel tank, the one with the fuel filter on the end is the main fuel line.
Aug 10, 2013 | Poulan Pe550 Gas Edger
STIHL FC 90
needle nose pliers and a lot of patience.. best to disconect the fuel lines from the carb, remove the tank and remove the fuel line and gromit from the tank. filter come out with it. replace it then work in reverse till its back together.
Aug 11, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
The fuel lines have rotted out of the edger gas tank. How do I fix or do I need to replace entire tank with new fuel lines?Since there are no male fuel line connections exiting the fuel tank and just two...
Jul 12, 2009 | Poulan Pe550 Gas Edger
Cracked fuel lines PE550 Edger
Hi Dan,
Yes, more than likely you will have to remove the screws on the back of the trimmer to remove the gas tank.
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jun 13, 2009 | Poulan Pe550 Gas Edger
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
246 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
