Question about Nortel Meridian M7208 Corded Phone
Feature 812 password?
Trying to clear "Calls For you" but when i try feature 812 it prompts for password. when i enter the user's PW it says "Invalid password"
3 Suggested Answers
SOURCE: T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Posted on Jul 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: I need to change our
You must call your IT department - or whoever set up the phone. This phone does not have a built-in answering machine/voicemail. A seperate server is required... and password is set by whomever set it up originally.
Thanks!!
Posted on Aug 17, 2010
How to softwhere reset GTX75 airtyme torrid mobile
Try this: The web interface offers a simple way to reset to factory defaults. It is necessary to login to the phone`s admin account to perform a full reset. Go to the "Advanced" screen. Click on "Factory Reset" then "Submit" and "Reboot phone". Early manufactured phones can be reset to factory defaults, including admin and user passwords, using the undocumented ATE menu feature. 1) Invoke the ATE menu and wait for the "Func No:" prompt. 2) Enter 37 and press the green key. Wait for "Success" and press red key. 3) Enter 38 and press the green key. Wait for "Success" and press red key. 4) Enter 41 (=Clear User Data) and press the green key. Wait for "Success" and press red key. 5) Turn the phone off and back on - it should be totally cleared and the default passwords will be set. WARNING: Performing the ATE reset will also clear the phonebook entries and all user-specific settings.
Apr 16, 2016 | Cell Phones
How to log in
Hello, I'm not sure which type of wireless router that is but most router to log in have the same user and password for default.
User: admin
PW: admin
But first, you must be connected to the router via Wi-Fi or by LAN cable.
Follow these steps:
1. Make sure that you are connected to the router.
2. Find out what is your gateway, this is the IP address from the router. You can google by your router model or check the instructions, also most router have the IP address in the bottom of the router.
3. Open a web browser and type the router's IP address, click enter.
4. If everything is correct, a new window should be display prompting to input the user name and password, remember to try admin.
If admin doesn't work, then try:
User: root
PW: 1234
Hope this solve your problem. Good day.
Mar 11, 2014 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
I need to reset, bypass, or remove the HDD1 PW
Shutdown The System
Press ESC and Power button together
Enter the passwords if prompted
Press F1 to enter the BIOS
Select the password field (it shows Registered)
enter bkspc or space
enter your existing password
press enter
It prompts for New password
Just enter
Repeat for verify
Now password is Unregistered
If you found this post helpful , please rate it!
Regards
1234s282
Apr 17, 2010 | Toshiba Satellite X205 Notebook
How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Mar 27, 2009 | Nortel Meridian M7208 Corded Phone
Intel 945 GCCNL
Clear the CMOS in case of an emergency.
Although the BIOS usually runs without errors, it can become corrupt in rare instances. If you're unable to enter your BIOS, or if you set a system password in the BIOS but forgot it, you might be able to fix the problem by clearing the CMOS memory. On some motherboards, this requires you to turn off and unplug your PC, disconnect the CMOS battery for a few hours, replace the battery, and turn on your PC again. Other motherboards have a CMOS clear jumper pin that you must move to a temporary position and then return it to its original position. Check your motherboard's manual to see which process you'll need to follow.
If a clear jumper pin isn't available and temporarily removing the battery doesn't work, check the motherboard manufacturer's Web site for instructions about resetting the BIOS.
Feb 14, 2008 | Intel Motherboard
Zoom X6 Password change and Firmware Update
Yes you are right. I agree with you. Real tech support really matters.
 I would like to add information about what you did when you downloaded the firmware, there are certain firmware for its problem. One firmware is design to fix this particular problem . Are there firmware version and short description on the website? You might run accross one that fixes "saving problem on User interface" that might be the solution. But you are indeed on the right track. its just that the website of Zoom maybe is not that detailed and userfriendly.
Oct 12, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Aug 21, 2007 | NorStar T7316E Corded Phone
Nortel Meridian M7208 Corded Phone Logo
41 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
