Bizhub c450 tray1 replenish paper while the tray is full of paper any clues please help
5 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Posted on Feb 10, 2008
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
Code c202 bz c451
This sounds like you have a piece of paper behind tray one.
1. Turn the machine off
2. Take out tray 1
3. Remove paper
4. Insert tray
5. Turn back on
If that doesn't help, you have and issue with the paper pick up motor. This is 99% of the time not the issue. The paper behind the tray is most likely your problem.
Oct 08, 2014 | Konica Minolta 4053-401 Black Laser Toner...
Paper won't pull out of tray1- even when full
www.lexmark.com/en_US/about-us/.../contact-us.shtml
Jul 02, 2014 | Lexmark Office Equipment & Supplies
No paper misfeed at ADF level but a misfeed message still displayed on my Bizhub c450
Well then check the paper draws and bypass tray. have the rollers in the draws replaced or clean. Select a different tray to use.
Mar 01, 2014 | Konica Minolta bizhub C450P Laser Printer
Problem with the Konica Minolta bizhub C450P Laser Printer Bizhub C450 error (C-0212) , HOW TO FIX IT?? PLEASE GIVE ME THE FIX STEP!! TKS!!!!!
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 16, 2011 | Konica Minolta bizhub C450P Laser Printer
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
Hi i have problems with my 7502 gestetner nrg photocopier
This sounds like a paper size issue. Check your papersize and oriontation in the tray(green selector font right or back left of tray) and check paper settings under the user tools menu for tray 1. let me know if that works, so we can trouble shoot.
Feb 23, 2009 | Gestetner DSm618 All-In-One Printer
Feb 04, 2008 | Konica Minolta bizhub C450P Laser Printer
76 people viewed this question
jasbo
jasbo
