Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
One of the remotes does not work.
I would like to buy a new remote for my Craftsman 1/2H.P. garage door opener.
  • 16 Answers
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Dec 29, 2014 | Craftsman Sears Liftmaster Garage Door...
I have a Craftsman garage door remote dated 06-98 that won't work. I replaced the battery and it still doesn't work. Can I take my remote somewhere to see if it can be repaired or should I just go to...
Do you have any other remotes that work? It could be the receiver that has quit. If you have other remotes that work your best bet will be to replace the one that isn't working but the opener will need to be programmed to your new remote.
Jan 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is the Craftsman 139.53681B remote compatible w/ 139.53753 remote
They have changed the radio frequency and the two will not work with each other.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door remotes and keypad won't hold the code.
DID YOU BUY THE KEYPAD AND REMOTES WITH THE OPENER. IT SOUNDS LIKE YOU MAY HAVE THE WRONG ONES FOR YOUR OPENER.
CHECK THE FREQ. AND IS IT ROLLING CODE.
Mar 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my old remote to work with my new garage door opener
buy new remotes. New opener is 315 mhz, old are 390 and not compatible,
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
THE ODDS OF IT WORKING ARE SLIM
YOU CAN BUY A UNIVERSAL REMOTE FROM CHAMBERLAIN / LIFTMASTER / CRAFTSMAN THAT WILL WORK WITH YOUR EXISTING REMOTE A MUCH BETTER SOLUTION.
HOPE THIS HELPS
May 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
