I have a canon ip 1700 and i have been trying to print but all the printer does is pull the paper so far down and then stops pulling. Or it will just pull one side down
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Error code 6A00 shut down machine. How do you fix it?
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Printer jams
try to clean the printer rollers with acohol it should work
Jul 23, 2009 | Office Equipment & Supplies
Error Code 6A00 on Canon MP830
try this 1. Opening the cover and wait for ink carriage to center 2. Pull out power cord 3. Pushed carriage to far left (should slide easily) 4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear. 5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel 6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white. 7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down 8. Slided carriage back to original position 9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Jun 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer does not fully pull paper...
You probably need to clean the rollers that feed the paper. Check your manual or go to Cannon web site.
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
CANON IP 6700D ERROR6A00
  1. Problem similar on canon ip4300 was solved by removing semi dry ink from black sliding rail. White plastic slide was stuck to the right side (spring was still stretched when printing head I moved to the left). Slide the white plastic slide to the left and clean the rail. This slide must be free to move left and right.
May 27, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
53 people viewed this question
jasbo
jasbo
