Installed new "O" rings for the spout and new diverter. Now with the water turned on, pressure is very low, removed aerator same problem. did not replace cartridge.
SOURCE: Moen one handle kitchen faucet very low water stream
if the pressure is good with the head off then you can probably get a new head for it u shouldn't have to change the cartrige. it sounds like the head is clogged so plastic pieces in the head to help save water "water savers" it is hard to clean them i would try changing the head u should be able to find on for a moen, u buy for looks u buy it for life. take the old head with u when u go to buy a new one so they can match it up to the right one.if you can't find it and a lowes or home deptm try a plumbing supply house
Posted on Apr 19, 2009
SOURCE: No water pressure in kitchen sink. Not the aerator.
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
Posted on Apr 25, 2009
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
Aug 21, 2017 | Moen Plumbing
Dec 28, 2013 | Moen Plumbing
Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
Jun 10, 2011 | Moen 7065 Vestige Single-Handle Kitchen...
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
Apr 23, 2011 | American Standard 4271S 'The Standard...
Dec 04, 2010 | Moen Home
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
May 20, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Dec 03, 2009 | Moen Plumbing
73 people viewed this question
