Question about Magnum DeltaForce CB Radio
Rk 56 switch replacement
The wires have come lose from the ptt switch on a rk56. the mic is used on a Galaxy radio
Check e-bay they have replacement switchs real cheap,5-10 dollars.they are also easy to change with minamal soldering skills.
Posted on Jan 14, 2009
Microphone not working
I think it is safe to say 90% of radio problems are microphone. You get a cheap one when you by just about any radio. I believe you are seeing the meter move but not getting audio from your talkback. No matter remove the mic jack plug from radio. For you particular radio looking at the end of the jack notice the small raised numbers. These female connectors no matter the mic type wired for this radio model has the following wires connected or in your case disconnected. 1-(Ground) 2- (Audio) 3-(Transmit) and 4- (Receive).
A RK56 mic would be my suggestion Astatic 636L the second choice a little cheaper but audio it not a crisp.
Don't waste your money a repairing the mic or buying a diesel or road pro or even a cdl mic like a cdl 56 or that Skythumper they are RoadKing 56 wannabees. Sorry about the rant my point is RK56 is Quality.
Apr 12, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Mic plug wiring diagram for connex 3300
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
This is the stock mic wiring but why bother just order a RoadKing 56 it is already wired for your radio. I suggest Copper.com dont even consider a Skythumper it is cheaper but the quality is not there.
Nov 12, 2011 | Radio Communications
RK 56 Mic what order do the wires go on the connecter?
on the RK-56 mic is like this,but I don't know
about your radio.
red and shield= common or ground
white.............= mic audio
blue..............=TX
black............=RX
yellow not used
maybe this will help
Sep 19, 2009 | Magnum DeltaForce CB Radio
Turner Rk 56 mic
Here is the wiring information for a Turner RK56. If the picture is too samll for you too see or it does not load up, email me at rollincbmods@yahoo.com with the subject as RK56 wiring diagram needed, and I will email it to you.
Dean Pitts
Rollin CBs
May 30, 2009 | Magnum DeltaForce CB Radio
Wiring diagram for a road king 56 4 pin mic
If this is a Turner Roak King RK56 (not another brand), and it is a newer mic, here is the wiring information that comes with them when I get them unwired. If you are unable to see the picture, please email me at rollincbmods@yahoo.com, and use the subject "RK56 wiring information needed"
Dean Pitts
Rollin CBs
May 25, 2009 | Cobra 29WXNWST (40 Channels) 2-Way Radio
Microphone
If the radio receives OK and the TX red LED will not lit up when keying the mic, then it is a mic or mic cord or mic connector problem (or pin configuration). Internally to the mic, there is a switch for keying the PTT. This should be check down to the coiled cord to the connector.
If all of the above checks OK, then you would need to check the TX/RX regulator/switching circuitry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Need a mic wiring diagram for a emperor ts-5010 rk 56 mic
EMPEROR
TS-5010
Stock Mic Standard Hookup
1 - Audio
2 - Shield
3 - Transmit
4 - Chnl UP
5 - Chnl DOWN
For Turner RK56 mic
1 - White
2 - Shield & Red
3 - Blue
4 - N/C
5 - N/C
Black - N/C
Yellow - N/C
Hope this gets you talking on your new mic. Reply back or email me rollincbmods@yahoo.com if you need more assistance
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Jun 03, 2008 | Radio Communications
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Road king micophone
Most standard CB microphones are 4 wires:
Audio IN (from Mic)
Speaker
PTT (TX)
Ground.
To determine which is which on the radio side:
a. the Audio IN (from Mic) would read a high resistance to ground (chassis) of CB radio;
b. the Speaker when connected to the ground would activate the receive speaker. To verify, power up the radio, squelch all the way down, when shorted to ground, speaker will produce background noise/sound;
c. when PTT (TX) is shorted to the ground, the rig will transmit and the red TX indicator will light up;
d. Ground. when tested with an Ohmmeter to the chassis will read 0 ohms.
Hope this be of some help/idea. Pls post back how things turn up or should you need additional information.
Nov 12, 2007 | Cherokee CBS2100 40-Channels Base CB Radio
Radio Communications Logo
110 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
