I need to buy a Lien Chang inverter board part number AI 0068 for a Philips 170P5EB/27 monitor.
SOURCE: I have a L1930b with a bad panel. I have a panel
You can use the 5vdc from the monitor power supply
Service manual: http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=L1930B%20&kategoria=&kat2=all
I look at the diagram page 31, pin 1~3 is the VCC for the panel with notes for 12/5vdc, it can be connected to the 12 or 5vdc, so it must have a jumper on the board somewhere that will let you choose 12 or 5vdc for the panel, the main thing is that the rest of the panel pins match the original panel, please verify that first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
SOURCE: Philips 47pfl7403d/27 screen blanks, i
no, this is the t-con board, some panels have the inverter built in to the panel and some have the inverter as part of the power supply board. if you see two pairs of wires with extra clear plastic sheathing comming off the power supply, then the inverters are part of the power supply board. most likely the culpret. if this does not fix it, then one or more of the lamps in the panel are shorted keeping the rest from lighting. if that is the case, you are screwed...the lamps cant be replaced,the entire panel has to be replaced.
No never buy a TV that another person claims just needs a "part", if that was the case why haven't they fixed it? Very bad idea.
SOURCE: ssb board
Ssb board?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
1942LGR3P 715G1813 1 Philips ADTV1942LGR3P Power Supply Backlight Inverter
