Question about Dirt Devil Vacuums
How do i change the bag on a 1990's dirt devil model 085360
Have forgotten how to change the vacuum cleaner bag
reddevil6
  • 1673 Answers
SOURCE: How do I change the
To change the belt, take off the bottom plate, the belt runs between the brush roll and the motor shaft. But if it is blowing out dust, you may have a clog in the dirt inlet by the brush roll, or in the hose.
Posted on Mar 24, 2008
  • 208 Answers
SOURCE: repair chewed vacuum cleaner cord
take to an apliance repair shop or if your inclined repair it yourself by replacing the cord
Posted on Jun 21, 2009
woobie dog
  • 1273 Answers
SOURCE: HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Posted on Jul 12, 2009
SOURCE: dirt devil dynamite spinning thing isn't spinning
does the unit have a belt?
Posted on Feb 01, 2010
  • 11 Answers
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Posted on Mar 08, 2010
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
How do you change bag
Hi! Below are step-by-step instructions on how to change the bag on your vacuum. This vacuum takes a Dirt Devil Type D replacement bag. I have included a link to the instruction manual, as well as a link where you may go to purchase replacement bags for your vacuum.
1. To Remove: squeeze front panel release lever and pull towards you.
2. Grasp cardboard collar of paper bag with both hands and pull past raised locking tabs on the dirt tube. Dispose of old paper bag.
3. Important: Extend bag away from hole before installing. Press in opening to clear paper away from hole.
4. To Install: Push cardboard collar past raised locking tabs on the dirt tube with both hands. Be sure paper bag is fully extended and tucked in at the top and bottom.
5. Replace front panel by putting the two bottom tabs in the slots on the vacuum. Push front panel so release lever attaches.
http://bit.ly/1DEkilx
Type 3 Pack
Hope this helps!
Jun 01, 2014 | Dirt Devil Vacuums
Won't turn on
change the switch with a brand new one and that will fix the problem the switch has gone out on another dirt devil vacuum and that is so common it is hard to explain it is a defect in the way the switches are made
Mar 17, 2014 | Dirt Devil SD30035 Express Bagged Canister...
How do I put the filter bag in to dirt devil versa power
download the instruc.manual and proceed according. go to www.fitness.manualsonline.com or www. retrevo.com . God bless you
Jul 10, 2012 | Dirt Devil SD20000RED Versa Power AllinOne...
Belt change on hand held dirt devil
No, just the chrome plate that covers the brushes
Jun 27, 2010 | Dirt Devil Classic M08100 Bagged Handheld...
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
I have a dirt devil that is only 2 years old, I used it and sparks began to shoot out from the front grill area. I called dirt devil's corporate office at 12noon today July 25th, and was told that with out...
The sparks may be from the carbon brushes in the motor. Bagless vacuums do not filter dirt out as well as a bag does so dirt and grit gets sucked into the motor. Filters should be cleaned frequently and replaced at least once a year. If the filter gets clogged the motor can overheat. If you got two years out of a $39 vacuum you did well. Many people are lucky to get a year.
Mar 24, 2017 | Dirt Devil Vacuums
My dirt devil featherlite vacuum cleaner
that vacuum is self adjusting it will do it by itself
Jun 11, 2007 | Dirt Devil M085570 Bagged Upright Vacuum
Vacuums Logo
44 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Nick Olsen
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
