Question about HP Compaq Model La1905wg 19" Wide Tft Lcd Flat Panel Pc Monitor 519682-001 4
Input signal is out of range
I keep getting this pop up on my monitor, using an extended desktop from a laptop. Then the monitor goes to sleep mode. How to I get my monitor to remain active?
  • 55 Answers
SOURCE: Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Posted on Apr 30, 2009
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
  • 31 Answers
SOURCE: VGA no input signal, monitor is going to sleep
try this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061509&cc=us&lc=en&dlc=en&product=3351967
Posted on Sep 15, 2009
  • 31 Answers
SOURCE: Hp w1907 Monitor going to sleep
try the link provided
SOURCE: Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Posted on Feb 08, 2010
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Desktop icons disapear when h p pavilion pc goes into sleep mode
Open Control Panel, Power Options, set to High Performance, you didn't supply the model of HP or the OS?, change power plan or Advanced power settings, to Sleep and Hibernate to Never, adjust other settings. Always shut down your laptop when not in use, your laptop will last longer, extend component life and will not be subjected to power surges, remove the battery if used on AC for extended periods. A reboot everyday will reset the laptop's OS.
Jan 29, 2013 | HP Pavilion Computers & Internet
How can i keep the monitor from going to sleep mode while working?
in start-up menue, go to control panel/ hardware/power options, and change your power plan, change settings for monitor and computer to 'never', this will give you control over when it shuts down or sleeps
Jun 23, 2012 | Gateway Computers & Internet
The computer starts and the monitor instantly goes into sleep mode and cannot be restored. It first shows that there is no inputs and goes into sleep mode
It is possible that your video card is Gone!!! Try to connect the monitor to another computer (to a laptop for example) to verify if it works properly.
Jan 01, 2012 | HEWLETT-PACKARD Hp Pavilion Elite Hpe477c...
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Are screen savers good for TFT monitors
unless the monitors are being turned on and off frequently the sleep mode idea is alot more efficient
Mar 30, 2010 | Dell E197FP LCD Monitor
The monitor goes to sleep after a short time
This model is having a problem of backlite. please check it independently for hour or so. If the same sign then the problem may be with backlite.
You may also approach authorised service personnel for this defect.
Aug 09, 2009 | Samsung SyncMaster 920NW Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Within the control panel select performance and maintenance within that select power options.
Once in there check that the power is set for desktop computer and that never sleep on monitor or Hard disks.
If this doesn't work then press the OSD button on the monitor and scroll through the setting and make sure that there isn't one that is auto sleep mode after and amount of time.
Thanks J
Jan 02, 2008 | HP Pavilion Media Center TV m7360n...
HP Compaq Model La1905wg 19" Wide Tft Lcd Flat Panel Pc Monitor 519682-001 4 Logo
37 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
