Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Can i exchange the mounting brackets from craftsman 24443 snow blade onto 244281 blade
4 Suggested Answers
  • 49 Answers
SOURCE: craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Posted on Feb 06, 2009
  • 78 Answers
SOURCE: got a 42" snow blade and no paperwork with it.
Ok that snow blade attachment was Made for Sears/Craftsman by AGRI- FAB. Go to thier website. Email them that you bought model number xxxxxxx and there were no instructions in the box. They will either tell you how to down load the instructions or send them too you. I have had the best luck with AGRI-FAB they like happy customers.
Posted on Oct 22, 2009
  • 3 Answers
SOURCE: How to see if a used snow plow blade will fit my craftsman tractr
Underneath the hood of your tractor is a silver sticker with the sears item number for the correct snowblade. If its a craftsman snowblade it should have a meteal label on it with its model number the 5 numbers after the period need to be the same with what was under your hood to make it the correct blade
Posted on Nov 13, 2009
Attching a craftsman snow blower to craftsman tractor 247.288820
you must ask to your supplier manufacturer by matter of design machine. Take the toll free or website and ask them by ONLINE via chat and ge the support.
God bless you
Nov 20, 2013 | Garden
Install Plow on Sears tractor
Going with the garden tractor, I have one. The cutting deck should be removed primarily because the deck could drag on snow. Some of the pivot points for the blade go where the mow deck mounts. There can be an additional fixture to mount on the body of the tractor frame to operate the lift for the blade. There can be additional brackets to support the blade and offer a 4 point mounting system.
Dec 03, 2012 | Garden
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
I bought this dozer blade uses and cant figure out how to attach it to my tractor. Is there a mounting bracket that bolts onto the tractor? Are there any pictures of this or an installation manual with a...
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Nov 16, 2009 | Craftsman 16" High Garden Tractor Snow and...
Nov 12, 2009 | Craftsman 16" High Garden Tractor Snow and...
Got a 42" snow blade and no paperwork with it.
Oct 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman snow blade install instructions
Dec 14, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
77 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
