Question about Ace Hardware BRASSCRAFT 45458 "ACE" DUAL-FLO SHOWER DIVERTER VALVE
Shower diverter problem
My shower was leaking water through the faucet (just a small stream), so I decided to replace the washer in the diverter. The washer was pretty shot. After replacing it, the water works fine through the faucet, but when I turn it to the shower I got nothing. I losened the packing nut (? the outer nut on the diverter) and I got a little dribble out of the shower. This diverter sends water to the faucet when the handle is turned to the right and closing the valve and allows water to flow out of the valve when turned to the left (to the shower).
Any ideas why this would work before I replaced the washer, but not now? I replaced the washer with the same number thatt was on the old washer.
    Scholar:
  • 35 Answers
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Posted on Jan 12, 2009
Fix porcher reprise shower diverter
Sounds like your diverter is defective. You need part #M962110-YYY0A
DIVERTER KIT. (replace your YYY with the color code of your shower)
This is an American Standard part, you can find it online (unfortunately expensive.)
Alternately, you can try calling American Standard and tell them you need the diverter WASHER for your unit. Maybe they'll send you a free one, and you can simply rebuild your diverter.
May 02, 2014 | Porcher 5535.901 Reprise Deck Mount Tub...
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
When water is turned on, water leaks from faucet and hot/cold water handles but when diverter is engaged the shower works fine with no leaking from the handles or faucet. I have a three handle system. Any...
Write down the type and model of faucet you have. Most hardware stores have rebuild kits for faucets.( washers, rubber o-rings and or gaskets) You will have to turn your water off and do some minor repairs.
The kits come with step by step directions.
Dec 13, 2012 | Home
Installed a new moen adler tub faucet with shower diverter. When you turn on the shower water continues to come out of the tub faucet. Is there an adjustment or is it just the way it is??
Our Moen always dribbled a little since the diverter is metal-to-metal and doesn't really have any seal. The loss shouldn't be a stream though.
Nov 11, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Pull down shower diverted works, but allows bypass into tub
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
Aug 11, 2009 | Delta RP17453SS Standard Diverter Tub...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Ace Hardware BRASSCRAFT 45458 "ACE" DUAL-FLO SHOWER DIVERTER VALVE Logo
719 people viewed this question
Top Ace Hardware Home Experts
Donni Steen
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
