I pulled apart my AVR25II to remove candle wax from a candle that the previous owner had let melt down into the housing and onto the circuit board. On the main board just behind the 2 large capacitors, there is a 2.5 foot long gound wire that has a single plug. I cannot find out where the other end connects. My memory and knowlegde (and schematics) tell me where it goes, but there is no connector. Can anyone pull off the top and send me a snapshot.
Thanks
after pressing power on button, the switched ac relay clicks continuously, system does not come on,...
(More)
after pressing power on button, the switched ac relay clicks continuously, system does not come on, green light on dial blinks at rythm of relay. happenned before,and system used to come on after a few clickings, now it does not.
everything seems to work but the lights went out.saw nothing in the manual except to take it in for...
(More)
everything seems to work but the lights went out.saw nothing in the manual except to take it in for service.i am pretty handy at repairs on most things.
He goes off everytime i turn on the receiver.. This problem was caused during the installation of my...
(More)
He goes off everytime i turn on the receiver.. This problem was caused during the installation of my surround set. I wired the speakers via the subwoover with the receiver, then when i turned on the receiver it went off.. eversince i can not use my HK AVR 25 MK II :-(
My Harman Kardon AVR 25 MKII will only play through either the front speakers when the factory...
(More)
My Harman Kardon AVR 25 MKII will only play through either the front speakers when the factory " main in to pre" jacks (2 of them) are plugged in, or through the rear speakers only when the "main in to pre out" jacks are removed. How does one set this system up to play through both front and rear speakers at the same time? The owner's manual makes a couple of references to using a separate amplifier on either front or rear speakers....was this system just a POS to start with, and I was supposed to buy a separate amplifier to use with it?
