Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE 3t started leaking from the side when filling
I have had my HE 3t for 3 years without incident, today while washing it made a strange noise, then finished the cycle. After another load I noticed the throw rug in front of the machine was wet. Figured I had overloaded it as this has happened before, but it continued even on a very small load. The water is coming from the left hand side during filling, doesn't seem to do it when spinning.
Thanks in advance for your help.
  • 640 Answers
Check dispencer and make sure its not cracked,,if not turn your water pressure down to the dispencer its splashing up and over running down..keep me posted onthejob
Posted on Jan 12, 2009
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
A technician once told me to run my Kenmore Elite 3t ( without clothing ) with some bleach to clean the machine on the inside. I do not have a "clean machine" cycle. However I don't remember how much...
Hello , pour the bleach into where the soap would go [about 2 cups], then fill your softner and bleach containers up as well , run a normal wash with an extra rinse , the bleach will not hurt it so the more the better but to a certain point. this should fix alot of the noticible mildew but to get it all use a brush and scrub with bleach.
Phil
Jan 12, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite 3t that fills with water when not in use
sounds like you have a bad fill valve it should only let water into the machine when the fill valve is energized. If water is coming in when unit is not in use change the valve.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 42922 HE 3t
sojds as if theresnot addeguate wate rsupply going to unit make sure
both hot and cold water is supplied and working to the unit
Apr 02, 2008 | Kenmore 46462 Front Load Washer
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Leak
Did it start to leak immediately? Or, did it start to leak as it filled about 1/3 of the way? You could have a loose air dome hose. This is the air hose that connects to the pressure switch. One end is connected to the switch and the other end is connected somewhere on the side of the wash tub near the bottom. If it came loose, this will cause a sudden leak. Check along the side of the wash tub (usually the right hand side on Kenmore) and see if the air hose is hanging free. If it is, reconnect it and your problem should be solved. Sometimes the hose will stretch over time and will not fit tightly anymore. There should be enough slack that will allow you to cut about 1/2" off the end and reattach. This will give you a more snug fit. This is about as inexpensive a fix that you can get.
Sep 06, 2007 | Kenmore 20722
Washing Machines Logo
85 people viewed this question
Sal De
fordexpert
Robert Rankin
