Question about Air Tools & Compressors
How to fix a air ace 3 peak hp air compressor
3 Suggested Answers
Gagg
  • 4 Answers
SOURCE: portable air compressor wont turn on
1st check for power at the pressure switch. Take the cover of the switch and make sure you have line voltage at the terminals from the wall outlet.
if no voltage>replace cord or plug end with proper gauge wire.
If voltage, then, while you have the cover off of the switch **Make sure it is not plugged in** and operate the on off switch and visually check the operation of the switch. You should see some flat copper terminals that, when the switch is turned on, kinda rotate and drop onto some other copper terminals. The connection is kinda like points on a old car ignition, little pads on each copper thingie contact each other. I have seen these little pads become pitted and burnt from arcing. Try to clean these with a small file or pick if they are corroded. Get some electrical contact cleaner and clean the switch completely, *it is not only electrical, but is also mechanical*. Switches will intermittantly work, replace the whole pressure switch if there is heavy wear, charring or working intermittantly.
If this is all good, check the wires coming out of the switch for power to the motor, replace if necessary. If this is ok..
You probably have a bad motor. I have not had much success in revitalizing motors, its usually better to just replace it.
Posted on Nov 21, 2008
compman66
  • 169 Answers
SOURCE: Hi, I bought a used Air Ace air compressor. 5 Peak
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is steve@morrismachineservicesllc.com
Posted on Jan 15, 2010
Testimonial: "I will get that info over the weekend and sent it to your e-mail Thanks"
Can my 3peak HP 4gallon pancake air ace compressor run air tools
Find the rated cfm the compressor is capable of producing at given pressure and select which tools meet air volume requirements.
Apr 23, 2015 | Air Tools & Compressors
How to change a regulator on a bostich pancake compressor
Usually they are just threaded into the unit, Empty the air, then remove it,
Oct 11, 2014 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Air compressor want build over 40LBS air!
It sounds to me like you have a bad pressure switch. When these go bad, it takes less pressure to close or open the contacts to shut the motor down. You can get a replacement from any Ace Hardware. It will come with basic install instructions. Just follow those and you should be fine.
Aug 03, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
My Campbell Hausfeld compressor model WL650101AJ will only pump to 80psi and will not shut off.
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Jan 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Hi, I bought a used Air Ace air compressor. 5 Peak HP, 26 gallon tank. I need a manual for this and can't find one anywhere. Thanks
Jan 14, 2010 | Air Tools & Compressors
I'm trying to find a check valve for a Campbell Hausfels 5 hp 25 psi air compressure
take ur valve off and go to NAPA and see if u can get a valve to plumb in place of the oringinal
Jun 29, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
99 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
