Question about JVC HD-61Z886 61" Rear Projection HDTV
My JVC HD-61z886 has no red colors. Just replaced the bulb with the jvc recommended part. Not sure what to do next.
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
tvtek
  • 1284 Answers
SOURCE: jvc hdmi????
Changing the output to digital only affectts the audio output stream such as Dolby Digital or DTS audio. Try turning on the DVD player first then the television and see if then it sees the DVD player. Otherwise using the component outputs most will never see the difference n picture quality. Good luck.
localwonder
  • 6784 Answers
SOURCE: how to replace bulb
Hi, i have retrieved your manual. it has all instruction on how to replace the bulbs. Click here for your manual.
A fix ya rating would be most appreciated. Thanks:)
Posted on Mar 05, 2009
SOURCE: I am trying to connect my Wii and Wii fit.
My wii fit came wireless. You have to wait until the update loads and then it will walk you through it with directions. Don't try and do it before because it won't work, we tried.
Posted on Mar 13, 2009
  • 10 Answers
SOURCE: i have a green hue to my jvc hd 61z886 61 rear
Hi
More than likely the lamp ,go to JVC website and get the part number for your lamp,google it and all the suppliers will come up,usually easy to change for customer and may be in your operation manual "how to"
Posted on Jun 04, 2009
JVC HD-61Z886 61 picture is dark. Is this fixable.
Could be dust in your light engine or build up on your mirrors.
Jun 21, 2012 | JVC HD-61Z886 61" Rear Projection HDTV
Lamp needs to bereplaced,,,,, tv jvc model 61z886, need to know model of lamp i need and where to buy it
Google "DLP lamp" and you'll get many places from which to order lamps. Go to one of these sites and they should have a search box. Enter your model number and it should give you the part number of your lamp. Try several sites if the first one doesn't give you what you need to know. Once you have your lamp number you can shop the various sites for the best price. Note: You can buy your lamp complete (with the housing it comes in),..... or just the bulb and replace the bad one in the housing (cheaper)..... if you have the skills needed. If not buy it complete with housing. If you change the bulb only,.. don't touch it with your bare hands. Most bulb only packages come with rubber gloves.
Aug 24, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Blue and red light flashes but no picture
I have the exact same problem. Replaced the bulb and ballast and the lights still flash rapidly. Bulb had burst before I ignored the onscreen replace warning.
Does anyone have a clue?
Nov 27, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
I have a green hue to my jvc hd 61z886 61 rear
Hi
Jun 04, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
How to replace bulb
Mar 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-61FN97 rear projection TV does not have any blue colors showing.
your blue componant cable is unplugged, eather on the tv, or on the cable box, 95% thats the prob, thats if you are using componant cables, those are red blue green, and red white for the audio
Jan 07, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Hdm ps3
Have you went into the video setup on your ps3 and changed the resolution to 1080p?
Dec 19, 2008 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-61Z886 61" Rear Projection HDTV Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
