Question about HP PhotoSmart C4280 Laser Printer
Print spooler install print spooler to make my printer work?
  • HP Master
  • 13,433 Answers
Print spooler is a program that runs in the background in your computer.
To start, stop or restart the program follow these steps:
  1. Press start
  2. Press run
  3. Type in the run box: services.msc : click OK (without spaces or : marks)
  4. press P a few times to find Print spooler from the listing
What is the status of the service? is it started? stoped? Disabled?
If the service is stoped right click on it and select Start.
If the service is disabled right click on it and select properties then change the start up mode to automatic, then click on start. Apply and OK
the service should be started and you should be able to print again.
Posted on Jan 12, 2009
  • 8 Answers
SOURCE: 1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Posted on Jul 10, 2008
  • 93 Answers
SOURCE: HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Posted on Aug 02, 2008
SOURCE: HP print spooler problem and error 1068. Want my printer back!!!
I'm on windows XP OS
I am having a similar problem and have been online all night needing a solution FAST.
I used to have a lexmark printer/drivers, which I hear cause the 1068 error.
I removed all those drivers.
In the "Services" window, I goto "Print Spooler"
If I attempt to start the service I get "Error 1068: The depedancy service or group failed to start"
Under "Print Spooler" properties / Dependancies Tab - upon clicking I get an error:
Service Dependancies
<Null>: No Such Interface Supported
From what I can see, I need a default RPC dependancy to be in there? I've set all the configurations to "Automatic" and recoverys to "Restart the Service"
I get nothing.
I also need to mention, I occasionally get an error upon starting windows XP, which says something along the lines of system32/services.exe error; restarting System in 1:00 (then it counts down and shuts off PC)
I really need this printer working tonight.
Thanks in advance.
Mike
Posted on Aug 21, 2008
my computer dosent print on my printer
Posted on Nov 15, 2008
SOURCE: Canon mp210 problems print spooler error
Error EP22
Posted on Feb 10, 2009
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
I do not seem to be able to print any documents even after uninstalling old drivers and installing new ones what is wrong
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X1270 All-In-One InkJet Printer
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Print spooler error during printer installation windows vista
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Nov 23, 2008 | HP Pavillion ZV6000 Notebook
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer Spooler service!
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP PhotoSmart C4280 Laser Printer Logo
143 people viewed this question
Ben Johnson
