Question about PC Chips M701G V1.1 Motherboard
Problems on PCCHIPS M701G Motherboard
Help me, I don't know how to connect the power switch to the power supplu unit! My PC casing is using non-ATX power supply unit, so how can I connect it? T_T
  • 1 more comment
  • hafizulrahma Jan 12, 2009
    urm, weapon can you provide the picture please? the power supply picture that fit for M701G Motherboard, and btw my old motherboard using non-atx power supply unit.
  • Brian Perry
    Brian Perry May 11, 2010
    When you install the power supply, it should already be connected to the power switch. You should be able to connect the new power supply to the on/off switch where the old one was connected. If this is a new case then the instruction manual should show you where to connect the power supply. Most motherboards have a keyed connection that connects to everything else. Its usually color coded too. Make sure the colors match up. If you can't figure it out, let me know more detail about the case and the type of power supply. It looks like some of your description got cut off.
  • Thomas F. Schneider May 11, 2010
    If you have an ATX mother board , you need an ATX power supply. Just buy the correct power supply for your case.
  • 58 Answers
Oh ok,
I didn't know if this was a new board your building from scratch or a power supply replacement on an old board. I should have asked that first to know what I was dealing with. Are you hooking up an ATX power supply to your motherboard. Your motherboard is an ATX motherboard.
Posted on Jan 12, 2009
  • 270 Answers
Connect your three pin socket in your power plug
Computer is not booting up. Usual blue light over power switch is red.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Feb 15, 2011 | Thermaltake Wing RS 101 Case + 430W PSU:...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Necesito el driver de sonido para la pcchip m701g
Mar 07, 2009 | PC Chips M701G V1.1 Motherboard
Motherboard P4M800CE-8237 Pin connection
Hi ohfs55, case's vary & so do the wire colors. The most common wire color for positive are colored wires. Blue, Green, & red. The most common color for negative is White & or black. I wasn't able to find your manual. If you have the manual for the motherboard there will be a page that will show where the positive & negative wire's connect for each jumper to the motherboard.
Without the manual I can not guide you through each connection. PW = power switch, RW =Reset switch, HD_LED = Hard drive LED ECT.
Oct 21, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
M701g v3
You will need the CPU socket type then download the sound mother board driver from the PCchips website, if it is "onboard sound":
Jun 29, 2008 | PC Chips M701G V1.1 Motherboard
No power
reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Jan 06, 2008 | Gateway Media Center 610XL PC Desktop
Matsonic ms9158ep sound drivers
plz mother board matsonic ms9158ep sound driver free down load
Dec 19, 2007 | Matsonic MS9158EP (DSMTSMS9158EP)...
PC Chips M701G V1.1 Motherboard Logo
157 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
