Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
How to replace toner in konica minolta printer 1690mf
  • 34 Answers
SOURCE: how do i replace the
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
  • 7 Answers
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Posted on Mar 04, 2010
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Posted on Apr 07, 2010
I have an error code 0310 on konica minolta magicolor 1690mf how do I get it off and get machine working again
The error code 0310 means the SOS signal is not detected within a given period of time after the output of the laser has been started.
To fix this clean the PH (laser) Unit by removing all the toner that gets inside. If that fails, you need to Replace the PH unit (p/n A034 R707 00). If the error returns again, replace the PRCB (p/n A034 H009 07).
Oct 11, 2014 | Konica Minolta bizhub Office Equipment &...
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Service call 14A3 in km 1690mf
The bright light that reads the image of the original document is bad replace it. comes as the scanner
try this site for start
May 29, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Change ymck toner
The toner cartridge has a chip that calculates the estimated usage of the toner and once it reaches it's capacity (per estimation), it will not print. The only thing you can do is to buy a new cartridge or buy refill toner that comes with a reset chip.
Aug 30, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Our Konica Minolta 1690MF only prints the centre of the page and not the rest of it, please help?
you may have to replcae the fuser . typically a fuser will have to replaced once every 4 toner replacements .
have you tried the support site at konica-minolta ?
http://konicaminolta.ca/business/products/office/printer/magicolor/magicolor1680MF/index.html
Jan 03, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
240 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
