Question about RCA RTB1100 Rtb1100 Blu-ray Home Theater System
Settings will not save
Hdmi settings go back to 480p when the unit is shut off. i have a full 1080p tv.
    Sergeant:
  • 256 Answers
That is because most of the movies on tv are not produce in a 1080 p (Signel) Your lucky if there evan 720p, In High Def, 1080p is just a big hype to suck people in,
Posted on Dec 05, 2012
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 31, 2011 | Televison & Video
New TV is hooked up from satelite cable via HDMI wire. We have it plugged in the HDMI port # 1. When we turn on the cable, the little box pops up saying HDMI and 480P. I ready the specs for the TV and...
jason_janick
You have settings in your TV and satellite receiver to set the resolution for the picture. I would first go into the TV settings and use 1080p for the TV resolution. Also, in the receiver setting, you have the HDTV setting. From the main menu, press 6 (System Setup) and then 8 (HDTV Setup). For TV Type change to 1080i. The Aspect Ratio should be 16:9. I hope this helps.
Ray Calo
DISH Network
Dec 28, 2010 | Element Electronics PLX4202B 42 in. Plasma...
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
My HDMI 1 input is set to display in 480p not in 1080p???
I think you have to change the settings in your HD box. Look on the diplay window of your HD box, if it says 480 there, thats where you need to change it so it will change then on your TV.
Mar 25, 2009 | Proscan 42LA30H 42 in. LCD Television
Hdmi resolution problem
Check the settings for the HDMI on both your TV and Amp. Compare them to your brother's set up. See if that provides any clues.
Try replacing the HDMI cable too, it could be faulty.
Jul 26, 2017 | Audio Players & Recorders
Hdmi
Your tv, 32LA30Q Television can only support up to 1080i, not 1080p, that is why you cant run it at 1080p, as the hdmi inpute only allow, 1080i, 720p, 480p and 480i signals.
Aug 25, 2007 | Proscan 32LA30Q Television
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Jan 21, 2007 | Denon AVR-4306 Receiver
RCA RTB1100 Rtb1100 Blu-ray Home Theater System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
