Question about Ovens
Delonghi dual oven dfs090do is not turning on. the timer/clock is not showing can this stop the fan oven working.
5 Suggested Answers
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
SOURCE: I have a Frigidaire Custom Imperial double oven
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Posted on Dec 11, 2010
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
I have a cookmaster 100 dual fuel the clock has gone out and the fan oven has stopped working the other oven and the grill stil work ok
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Jan 06, 2010 | Ovens
The markings for the controls on my Delonghi DFS090Do duel fuel cooker have worn off.Can I get an original picture of the control markings to re apply them myself?
I have the same problem. How did you do it? Did you write them yourself on the metal? Did you buy them?
Thank you.
Jorge
Oct 03, 2009 | DeLonghi Ovens
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Delonghi DFS901SS
have the same problem as you all. i myself removed the top of the hob to reveal a burnt out control switch . i have looked online for a replacemrnt , and it is £66 plus vat from delonghi but have found a cheaper one for £42, cant remember which site it was but type in cooker name and model on google and you will see it for yourself . good luck to you all, it seems like an easy fix
Mark
Oct 21, 2007 | Ovens
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
