Rca 25424re1 screen is stuck on please wait
I get no dialtone, pushing buttons does nothing, is there a reset button on the phone to stop what is causing the phone to get hung up on this mode?
  • 5 Answers
SOURCE: Archos 605 is stuck in Demo mode
Should be the same as it was for my archos 604, try my instructions at
http://thepoetrydude2.blogspot.com
Posted on Jan 03, 2008
ctf1800
  • 4402 Answers
SOURCE: Crashed?
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: RCA OPAL M4208RD-B Goes to please wait screen and stays.
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Posted on Jan 06, 2009
ginko
  • 19396 Answers
SOURCE: tv has got stuck on standby mode
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
I have 2 remotes to my RCA LED52B45RQ tv. both are RCA remotes and we are having the same problem with both... they randomly stop working (nothing works). power button lights but nothing happens.
You may have a stuck button and not know it. look at the led end of the remote with the camera on your cell phone. If you have a stuck button you will see the led flashing. If it isn't flashing. push a button to see the led flash. Keep pushing different buttons to see if the led will flash without holding a button down. If you push a button and the led doesn't flash, it can be worn carbon button or the ic in the remote is failing If this test procedure does not find why the remotes die. you may want to invest in a a remote that will never become obsolete or worry about codes to operate more devices. It's called a Harmony remote. It's awesome. Logitech Harmony universal home theater remote and app
Sep 13, 2016 | RCA Televison & Video
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
RCA Visys model #25424RE1 how do I setup voicemail
The 25424RE1 isn't a voicemail system. Please consult the documentation for whatever voicemail system you're using.
If you require further assistance, please repost your question specifying the voicemail system you're using.
Oct 19, 2012 | RCA ViSYS 2-Line Speakerphone
Motorola md841 phone states out of range. Have tried unplugging it a new battery and pushing EVERY button:). No change to status
No clue what a SIM is this is a RCA office phone model # 25424RE1.
Batteries are new. Ive unplugged every cord. I have the diplay that works, it show me how many calls ive had etc, but the background wont light up when you pick up the reciever and it wont let me dial or answer the calls.
Oct 19, 2012 | Lands Phones
Need a manuel
You may download a copy of the manual here.
Aug 09, 2012 | RCA ViSYS 25424RE1 4-Line Telephone, Blue...
Message indicator light will not go off even after unplugging for over 20 minutes?
I found a solution: Hold the "Delete" button (left button below the dispaly screen) for 1-3 seconds and it will turn off. Figured this out after breaking my head and almost breaking the phone trying to get it to turn off! Hope it helps youl.
Jun 13, 2011 | General Electric RCA-25424RE1 4-Line...
How to increase volume
To change the ringer volume: while the phone is on the hook press the Vol + or Vol - button. The phone rings according to the current setting. Tap the Vol + or Vol - button to adjust the volume one setting at a time. The phone stores the setting after the last button press.
To change the speakerphone, handset, and headset volume: while the phone is in use in the desired mode, press the Vol + or Vol - button. The phone stores the setting after the last button press.
The above is from pages 14-15 of the manual at
http://www.rca4business.com/products/pc/pdf/instruction-book/25424RE1.pdf
Jun 11, 2010 | General Electric RCA-25424RE1 4-Line...
Meridian 9516cw desk phone in continuous"Please wait"preboot mode
Same issue. One day I walk in my den and the phone is at Please wait..., the Handsfree/Mute LED is blinking, and there's a tick TOCK sound (fainter tick when LED is off, louder TOCK when the LED is on). Tried unplugging for hours, 'raking' the buttons, unplugging all cords. It is fairly old and perhaps the logic board has failed.
Oct 16, 2009 | NorStar Meridian 8314 Corded Phone
Player won't work
Go to the RCA Opal website and download the newest firmware. That may clear it up.
Aug 21, 2007 | RCA OPAL M4001 MP3 Player
55 people viewed this question
 Grubhead
Grubhead
