Question about Emerson MW8102SS 1100 Watts Microwave Oven
Mw8115ssw no power
Emerson mw8115ss, power just went off, plugs/electrical all working, but not microwave. Is there a fuse, reset button that can be used, where would a reset button be located. Is this a common problem with this model?
  • 1 more comment
  • RodneyK Jan 16, 2009
    I have the same problem. Went to use the microwave and it was completely dead, no clock, nothing. I checked the cord to make sure it was still plugged in and it was ok. I took the cover off the microwave to check the fuse and its still good. I then checked the voltage with a volt meter. I have voltage at the plug and across the fuse but then I lose all the power. I can't seem to follow the traces on the circuit board and I don't want to work on it with it plugged in. Does anybody know where I can get a wiring diagram or schematic?
  • lmostrander Jan 27, 2009
    clock works- reset everything- keeps time
    will count down but will not heat up. Just one year old
    is it trash
  • gleneakins Feb 16, 2009
    No power on microwave is there a fuse?
  • Emerson Master
  • 9,098 Answers
There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Posted on Jan 12, 2009
I have a emerson 8115 ,I replaced the fuse ,when i press any key on the pad it blows it .HELP DOC
Posted on Feb 16, 2009
Everything works, but don"t heat.
Posted on Jan 22, 2009
How do i get the back off my emerson microwave
Screws are probably on the bottom of the microwave - then the whole side and top come off - then you have access to the back - i doubt it has an internal fuse though! I presume you have checked the plug fuse.
Be very careful - microwaves generate a massive electrical output and will fry you in a second!
May 13, 2014 | Emerson Fans Emerson MW8115SS Microwave...
My emerson mw8115ss is working but not heating up how do i change fuse
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 10, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
My Emerson MW8115SS microwave works but doesn't heat anything up, what could be wrong? And is it a easy fix?
Hi there.
Obviously it is "not working"
Could be an internal fuse or the activator is just finished.
Iceman.
Nov 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
No power
Usually they do have fuses in side as well as the one in the mains plug. With microwaves I would get an engineer rather than take it apart yourself.
Mar 11, 2008 | Microwave Ovens
Emerson microwave oven model mw8115ss
There is not much you can do about this. There may be a reset button on the control panel, try it. You can try slamming the door a couple of times & looking on the back for any fuses. If this fails, scrap the oven & get a new one, as they are generally not worth repairing.
Jul 02, 2007 | Emerson MW8108P Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
740 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
