Question about Proform Exercise & Fitness
I cannot remove the end cap from my pro form 730 treadmill
SOURCE: Treadmill stops running
If you don't have the manual, see if the proform website has a PDF version available for download. They seem to have a lot of past models available. On our system (ProForm T10.0, PFTL0505.0) an E2 error meant the belt speed (according to the sensor) was too slow. The treadmill should come up to the selected speed within 7 seconds or this error is triggered.
Icon service turned out to be knowledgable and fair, although they can be hard to get ahold of on the phone. If you hold too long, then you are given a chance to enter your phone number. I had to contact them several times, and they did call me back each time I left my number.
Unfortunately several things can cause the belt not to run or not run well, so start with the easiest to fix items first like lubrication and tension adjustment (get a manual from the website if you don't have one--it covers this adjustment). Maybe clean the speed sensor wheel with compressed air or a q-tip (our model had a slotted wheel on the drive shaft which spins through an LED light detector).
If the speed is off, try calibrating the treadmill. Icon service can tell you how to do it (it's not in the manual).
Posted on Jan 12, 2009
SOURCE: I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
bwinton
  • 83 Answers
SOURCE: treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
I need a wiring diagram for a pro form 730 treadmill
There are many different kinds of Proform 730 models. Please search for or find your specific Proform model here and look at the parts list for the accurate wiring diagram for your model.
Oct 20, 2011 | Proform 730 Folding Treadmill Model...
A friend of mine gave me her old Sears Pro Form Space Save 730 SI Treadmill..I was able to use it twice and for some reason I cannot start it...It lights up but does not move...I do not have a Manual..Is...
hi,
I have the manual of Pro Form 730si . If you can give your email as a replay for this then i will sent the manual to your email id. I can't upload the manual through fixya. Because its a pdf file.
OK
Sep 18, 2011 | Proform Exercise & Fitness
Describe how to unfold a treadmill, pro form ex
May 31, 2010 | Proform Exercise & Fitness
My pro form 730 runs then its stops after about 30 mins
If you have not lubricated the deck I suggest you doing so you may purchase the lube @ Gymparts.com Part # TM001
May 13, 2010 | Proform 730 Folding Treadmill Model...
My treadmill will not incline. when you press the
Wondering if you found a solution to this problem yet? I seem to have the same situation with my 730cs treadmill. It is inclined and will not move up or down...thanks.
Mar 02, 2010 | Proform 730 Folding Treadmill Model...
My belt is skipping on my Pro-Form 750
At the end of of the running belts in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Exercise & Fitness
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
