Question about Amana Kitchen Ranges
Cant open door to oven
I can move the slide lock left to right without any problem. But I can not open door!! It has been more than 24 hours, the oven is off. I even unplugged it. Still can not open door. It seems it is being hung up on something.?
  • kmilewski Jan 12, 2009
    yes i pulled REALLY hard on the door. Didnt work!!
    My oven is an Armana, model ART 6001W
  • kmilewski Jan 17, 2009
    It's plugged in. Still will not open!!!
  • 916 Answers
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Posted on Jan 17, 2009
  • 728 Answers
Maybe the slide lock has broken off and the broke piece is jamming the door into the lock position. If you can do it yourself, you may need to unscrew the oven and check the slide lock for broken pieces and remove them.
Posted on Jan 12, 2009
    Brigadier General:
  • 5,158 Answers
You have mentioned you unplugged it... plug it back in and try again
  • Roberta Smith
    Roberta Smith Jan 17, 2009
    I believe there is a latch on both sides of the door... are you getting them both ?
    Robert
  • 58 Answers
Have you tried pulling really hard?
Oven will not unlock after self clean
Unfortunately, the high temperature limit sensor probably failed during the self-clean cycle. The oven control unit will not receive the signal that the oven is cool enough to unlock the door without the sensor.
If the oven is cool, you can try unplugging the oven for a while and then see if the oven unlocks after power is restored. Pressing the Cancel button several times (or pressing and holding Cancel, depending on the model) may also work. Sometimes, starting a new cleaning cycle and then stopping it (and waiting for the oven to cool) will work.
However if the sensor has failed, the above steps are unlikely to work. You can try to move the lock manually. On some models, you can use a bent coat hanger to slide between the oven door and the frame and push the lock over. On other units, you might open the back panel and rotate the lock mechanism cam.
The oven will not work until the high temperature sensor is replaced. Sometimes the lock mechanism fails and that is what needs to be replaced. If the oven works, then look at replacing the lock motor.
I hope this helps. If your oven is under warranty, contact GE for the repair. Please add a comment with the model of your unit for specific information on the parts you may need.
Dec 29, 2013 | Ovens
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
How to open oven door after self cleaning? oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board
or
Try this to get the oven door open. Turn off the power, take a coat hanger and bent at 90 degree angle about 2 inches long. Turn the wire side ways along the top of the door, 2 inches to the right of center, turn your wire so the bent piece is down. Now pull out on the door and move the wire to the left. This should unlock your door so you can get to dinner. What may have happened is that the oven sensor has locked the door for safety. That does happen
Dec 03, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Ge wall oven door will not open
If you can not open this door, then the problem probably is that you stopped the clean cycle before it was finished. Restart the cycle, and set it at the minimum of 3 hours, and then when it is finished, it will release the latch that locks the door. I had this problem last night, and after the cycle was finished, the door latch was released. Hope this helps.
Take Care
Feb 14, 2009 | GE JBP70SKSS Stainless Steel Electric...
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Honda pilot door locks
It is because the door actuator is bad in those doors.
Replacements can be found at the dealership for around $60 or on Ebay for as little as $10. Number 5/24 in the diagram below. Actuator part # Left Side 72155-S5P-A11 & the Right side 72115-S6A-J01.
Expect to set aside at least 1-2 hours on the first replacement, lesser time on the ones afterwards. Be careful not to push parts in directions that they shouldn't be pushed in. Don't break any plastic parts/metal rods or connections - take your time.
1. Remove the plastic tab under the inner door latch.
2. Open the 2 small black colored screws.
3. Carefully swing the door latch attachment out by moving it down and out. Remove the rod and the electrical connection - there's a slot to press and pull-out.
4. Use a flat screw driver to carefully pry the window opening plastic area (its one piece and includes the cup holder). Remove the electrical connection - there's a slot to press and pull-out. Open the screw beneath the arm rest.
5. Use a flat tool (I used a metal putty 5-in-1 tool) to slide between the door metal and plastic areas - pull the plastic buttons/connections off, you'll hear them pop. Slide the door out.
6. Gently open the white plastic sheet about a quarter of the way from the top right down so you can reach in the actuator area (near the door latch - at the end of door with 3 screws). Remove the window guardrail, if its in the way - use a 3/8 bolt.
7. Use correct amount of force, without stripping them, open the 3 screws at the door latch.(Best to use a Handheld Impact Driver)
8. Take a good look at the connections inside. Disconnect the electrical connections (two of them) on the lock actuator.
9. Gently but forcefully (without breaking any plastic or other parts), push the metal connectors back and carefully remove the door lock actuator assembly from the door.
10. Replace with new actuator and assemble in reverse.
Nov 24, 2008 | 2004 Honda Pilot
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
How do you clean self-cleaning Maytag Gemini?
If the unit is a self-cleaner, you should remove everything from the oven (including the racks as the self-clean mode will remove necessary lubrication from the racks if left inside). If the range has a slide lock on top of the oven door, move it from left to right to lock the door, then press the self-clean button. If it does not have a slide lock, it should have a magnetic lock which will engage when the self-clean function is activated. The oven will reach approx. 800 degrees for about 3 hours. When it cools, you should see a white powdery substance in the oven. Wipe this up and you are done.
Mar 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
60 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
