Question about Acer Aspire 5520-5908 Notebook
SLOW loading pgs., system tray error-navigation is unidentified.
My computer is barely crawling! Won't hardly load pages & displays a
''navigation is unidentified'' message in the system tray. And most of the time says page is done with error. Barely can load my gmail, & I can't retrieve it. I have ran scans in my avg, spybot,& in
Windows Defender. Shows no viruses or spyware present. Updates for Winows, AVG, & Spybot, are all current up through today. Please can you tell me what I can do? I'm giving you my daughter's email address
here in my details since I can't get my mail. Please send me an email there as well: cgigstad@mripa.org
Linda K.
  • Thomas F. Schneider May 11, 2010
    Have you cleaned and defraged the hard drive?
    Tried system restore to an earlier date?
Computer running very slow
follow these steps to resolve your problem
- Delete programs you never use
- Limit how many programs load at startup
- Defragment your hard drive
- Clean up your hard disk
- Run fewer programs at the same time
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that made your system slow
Oct 02, 2013 | Audio Players & Recorders
Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
Aug 28, 2007 | Dell 3100cn Laser Printer
Error loading operating system
You need to reinstall the Operating System with the help of recovery disks.
Feb 11, 2013 | Acer Aspire 5334 15.6" Hard Drive Caddy...
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
How to format a hard drive
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
Dec 16, 2012 | Western Digital HDD WD5000AAKX 500GB SATA...
Error 0xb9000003
* Where exactly you are receiving this error, on the printer display or on in computer?
* When exactly you are receiving this error?
* Does the unit print a self test page? Steps are given below:
1. Load the paper tray with unused plain white paper.
2. Press Setup until Print Report appears on the display, then press OK.
3. Press OK again. The self-test report prints.
:) Dr Tony
Apr 17, 2010 | HP PSC 1610 All-In-One InkJet Printer
I don't know where to insert the pages to be faxed
Load the paper into the document feeder on top of the machine.
Jul 06, 2009 | HP LaserJet M1522nf Multifunction Printer...
Very very slow loading taking over 10 minutes from boot speaker stuttering when playing music
(Assuming Windows XP, since OS not reported.)
The problems you note are indicative of excessive hard drive activity. The sound issue, particularly, indicates possible disk thrashing as Windows runs out of memory and has to resort to a (fragmented?) pagefile. Each of the issues below is likely:
1. Hard drive heavily fragmented or has file system errors. Solution: boot into Safe Mode (During boot, Press the F8 key repeatedly to bring up the Boot Menu, select Safe Mode). Defrag: Open My Computer. RIGHT-CLICK on your C: drive. Select Properties> Tools. First CLICK on the button to check your disk for errors (just follow any prompts), then CLICK on the button to Defragment the hard drive.  NOTE: See #3 below for further information on defragmentation.
2.  While still in Safe Mode, run your anti-virus software, since malware can also cause the problems you note. Running your (up-to-date, I hope) anti-virus and anti-spyware scans in Safe Mode gives you a better chance of detecting and removing any malware.
3. Your pagefile ("virtual memory" file) and your Registry may be fragmented, and these two things aren't dealt with very well (if at all) by Windows' defragmenter. Solution? Pagedefrag (http://technet.microsoft.com/en-us/sysinternals/bb897426.aspx --just copy and paste the link into your browser.). It's a utility originally from Mark Russinovich, bought and now maintained by Microsoft. Just download, install and use it according to the directions at the page noted in the URL. Highly recommended for all Windows systems Windows 2000 and above.
4. Is your system tray full of icons? You may have too many programs loading and running in the background. First, start msconfig by CLICKing Start>Run and typing msconfig in the dialog box. Press the Enter key. In msconfig, go to the Startup tab and UNcheck any programs that
   a. load at startup and that
   b. you do not want loading at startup
WRITE DOWN THE CHANGES YOU MAKE so that you can reverse them later if you experience probems with one or more programs you need. "OK" your way out of MSCONFIG and restart your computer. A little faster? Good. Not enough faster? Go back to MSCONFIG and try UNchecking a few more.
5. You may have services running in the background that you do not need. Select the appropriate list from Black Viper's Services pages (http://www.blackviper.com/WinXP/servicecfg.htm) and make modifications to the Services Windows loads (and how it loads them) according to his recommendations. Again, WRITE DOWN THE CHANGES YOU MAKE so you can reverse them if necesary.
6.Too little system memory. Go to http://www.crucial.com (no, I do not work for Crucial nor do I get any compensation for recommending the company; I just like Crucial memory and like the company's guarantee/return policy) and run the memory configurator or select your computer from the drop-down lists. Buy more memory. Preferably as much as your computer can take.
7. Sadly, the symptoms mentioned can also indicate hardware problems--failing hard drive, heat issues, internal connections with built upo resistance because of deposits, corrosion. Those would be difficult to diagnose with the little info presented, and some impossible absent physical examination. Suggestions:
Buy a can of compressed air for electronics cleaning (no, you CAN'T use your compressor you hook your paint sprayer to :-)).Power your computer down and unplug it.  Open your case, GROUND YOURSELF on bare metal and use the compressed air to blow all the dust bunnies out. TAKE CARE when blowing dust out of the CPU fan and heat sink! Gently--GENTLY--touch the fan to keep it from spinning as you blow dust off it and out of the cooling fins of the heat sink.
Interestingly enough, I had a computer service call once where the only apparent issue causing very slow running was heat buildup from excessive dust bunny population. *heh*
Jul 17, 2008 | Computers & Internet
DEST ERROR CODE
I HAVE A SONY MODEL MHC GNZ55D AND IS WRITING DEST ERROR ON THE DIS PLAY AND CANNOT LOAD OR OPEN DISC TRAY PLEASE HELP AM A TECHNICIAN
Display indicates 'DEST ERROR' when any DVD functions are used.
May 16, 2008 | Audio Players & Recorders
Acer Aspire 5520-5908 Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
