Question about Lexmark Office Equipment & Supplies
Need connection cords for Model# 4444-101
I had my power cord and computer to printer cord stolen and need to replace them. Am having a problem figuring out how to obtain them since the person who answered my call for assistance said that there was no such model number. He referred me to 1--877-577-2787. That number is "Down due to emergency conditions", Is there any way of knowing how long that might be, or is there something else I can do at this time?
    Top Expert:
  • Lexmark Master
  • 45,139 Answers
Fixya does not sell replacement cords.
Posted on Jul 19, 2017
Buffalo12980
  • 625 Answers
SOURCE: Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Posted on Sep 17, 2007
  • 8 Answers
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
Posted on Mar 27, 2008
Need to know how to connect 4 wire power. There is a 3 wire cord connected now.
Posted on Oct 01, 2008
SOURCE: Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Posted on Nov 03, 2008
  • 2692 Answers
SOURCE: need to replace power cord
Here are the Sears links to purchase both the part and the manual.
http://www.searspartsdirect.com/partsdirect/searchByPartDescAction!searchByPartDescription.pd?brandId=0582&productCategoryId=0645000&modelNumber=11633922300&backToLink=Return+to+Sub+Components+list&partDescriptio
Posted on Dec 31, 2008
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
My Canon i6500 Printer has been in storage for a while when we moved house . I think there is a cord missing. Can you help. I only have one cord which is a USB to connect to the computer, is there a cord...
There is a mains power lead needed for this model of printer.
I don't have the same model printer here with me, but as far as I know from this range, you will need a standard *figure-8* lead, available from most shops around. Many £1 shops have them too.
Nov 07, 2010 | Canon BJ I6500 InkJet Printer
HELLO- I NEED NEW POWER CORDS TO CONNECT MY XEROX DOC 12 TO THE COMPUTER TOWER WHERE CAN I GET AFFORDABLE USED REPLACEMENT CORDS? THANK YOU- KRIS BOLINE
if cords are the power cable, then go to maplins or any place that has electrical hardware, 13 amp kettle lead is what is needed
Sep 27, 2010 | Xerox DocuColor 12 Printer
Need operating manual/parts for Sharp Copier Z-85 III
It is an old model. Good little copier though. The power cord should be no problem as it takes a standard power cord for most printers like HP or almost all computer power cords. If you don't have one lying around you could check about any used computer store.
The operators manual will be next to impossible.
Nov 03, 2009 | Sharp Office Equipment & Supplies
Need replacement power cord for HP psc 1210 printer.
This printer utilizes a power cord identicle to one used on a PC.
Sep 30, 2009 | HP PSC 2210 All-In-One InkJet Printer
Can't connect to computer to do printouts
I believe the cord between printer and computer is an ordinary USB cable, available from lots of places in different lengths, and I suggest you try to get one and see if it does the trick.
Sep 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Need to purchase a power cord and the cord that connects the printer to the computer for a HP LaserJet 6p Printer, Model C3980A. jmtthompson@yahoo.com
Power Cord = 8120-6805
Parallel Cable = 5063-1254
With these part numbers you should be able to purchase them anywhere that sells HP parts.
Aug 03, 2009 | HP LaserJet 6p Printer
Garmin windshild suction cup mount with power cord stolen
You should be able to get a replacement at any of your local best buys or radio shack retailer.
Apr 16, 2009 | Computers & Internet
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
