Question about Bosch Saws
Need new brushes for 9" Bosch GWS 21-230H - Bosch Saws
2 Suggested Answers
  • 14 Answers
SOURCE: Just Stopped..No spark or anything as if plug had
The brushes probably need to be replaced.
Posted on Oct 08, 2009
Testimonial: "Having taken out a brush I would say your 100% right..So now to find a set of brushes...I am more than happy with the answer and the speed of response"
How to change brushes on a bosch 1194vsr
There should be two brush holder screws, one on each side. Unscrew them and pull the brushes out. Replace them with new brushes, screw in the brush holder screws.
Jul 31, 2014 | Bosch Drills
How to remove flange and get blade off, having put on wrong way off power tool gws 23230 or 0601 362 042
Unfortunately there is not an easy way. The only way you can remove it , it is called brutal force. :)
Sep 12, 2013 | Bosch Electrical Supplies
How to change brushes on bosch11227e rotary hammer
Disconnect the power cord from power supply first---ON most electric machines the brushes are under a small threaded button on either side of the motor case near the end. They are plastic and when unscrewed will have a spring around a copper wire attached to the brush. Just pull out and push in the new units ensuring that any curve of the brush will fit around the armature. Retighten the plastic cap.
Jul 09, 2012 | Bosch 11240 1-9/16" SDS Max Combination...
HI. I have a bosch wfo2466 washing machine and need to replace the motor brushes. does the end cap need to come off to do this or is there an easier way? I have successfully removed the motor from the...
You do not need to remove the end cap.Pull off the brush leads, and ease out the terminal ends of brushes with a pair of taper nose pliers..pull the old brushes out, take note of which way the shamfored end of the brushes are facing in the holder.
Push new brushes into holder and compress the springs as you are pushing them down, locate terminal ends into slots of brush holder.
This should help you with your problem.
Good luck.
Thankyou.
Nov 27, 2009 | Bosch Classixx WFO 2466 Front Load Washer
WHERE ARE THE BRUSHES FOR BOSCH EXCEL 1400 EXPRESS, ARE THEY SEALED IN THE MOTOR .CAN YOU REPLACE THE BRUSHES OR DO YOU HAVE TO BUY A NEW MOTOR?
Some of the motors Need A HALF motor which is the end section with brushes fitted, quite expesive if you can get brushes they are around 5 times cheaper if you check a parts website that will tell you which one u need...
Oct 01, 2009 | Bosch Exxcel WFO 2865 Front Load Washer
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Saws Logo
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
