Question about LG LRSC26910 Side by Side Refrigerator
Water dispenser wont shut off
Changed the water filter and when we we went to get a drink the water would not shut off. I can shut the water off from the line under the sink and it will stop (or quit flowing) , I turn the water back on and the dispenser stays off until we trigger the dispenser again.
    President:
  • 2,692 Answers
Something from the filter went into the dispensor valve and is holding it open. You can try to backflush it with a can of air by disconnecting the filter pushing open the valve while holding the can straw tightly while discharging it. You could also backflush it with water.
Posted on Jan 12, 2009
I have know water for drinking only drips
Have you changed the water filter lately? They need to be changed every 6 mos. They clog up and restrict water flow to your dispenser at the door.
Apr 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Drinking dispenser doesn't work..Only trinkles out water? Do you have a fix or idea?
hi it have a water filter if so that may to be changed. if not make sure the water going to refrig has good pressure. hope that helps
Oct 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
CHANGED FILTER, HUGE INCREASE IN WATER DISPENSER PRESSURE
No it will be fine. Just think about all that small particulate stuff the filter caught and filtered out of your drinking water. The pressure will drop as this filter begins to collect particles from your water and be back to about the same in a few months. Sea Breeze
Apr 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Water dispenser stopped working after changing filter
There is a built in system of valves on the filter connections that enable changing filters without turning off the water. IF the filters are not fully connected the valves wont open and there wont be any water flow. .
Feb 17, 2018 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Water wont dispense
Yes, if the filter gets clogged up to a point that it won't allow water to flow, it won't dispense. Replace the filter. Remember that the all the junk that the filter captures is better left in the filter than in your bloodstream... Hope that helps !
Aug 13, 2008 | Frigidaire FRS26R4A Side by Side...
Water dispencer
Hi. This is normal and there is nothing wrong with your refrigerator. Whenever you replace the water filter on any refrigerator, you must run a couple gallons of water thru the water dispenser until all the air from the new water filter is out. Use a large container to do this. The water will not stop when you pull a cup away because the water valves used on refrigerators are so weak it will not close until it has pressure on both sides of it. If you don't get the air out, the air from your new water filter can go to the ice maker and stop ice production. So flush the air out of your new water filter. The water you are drinking from your drink dispenser may not be healthy. It may contain a small plastic floating substance. This is part of the plastic that the water tank is made of. The chemicals in the water do this. You will have this problem even with a new water filter because the water tank is after the water filter. You have to replace the Water Tank. The water tank is located in the refrigerator section on the bottom back wall. I sell low cost new designed Water Tanks on Ebay as username: themackshack. Good Luck, Mack
Mar 18, 2008 | Whirlpool ED2FHEXN Side by Side...
LG LRSC26910 Side by Side Refrigerator Logo
566 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
