Question about HP Computers & Internet
HP TSS-25x11 LED Monitor ac power cord 100-240 vac input 50/60UL 1.5 A
  • 556 Answers
SOURCE: I need a new power cord
you can go to any monitor repair shop & get it.
just tell model no. or take the sample which is defective.
good luck.
Posted on Oct 11, 2007
SOURCE: LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Posted on Dec 10, 2007
  • 238 Answers
SOURCE: All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Posted on Dec 15, 2007
PyroPCMan
  • 405 Answers
SOURCE: ac power cord for HP vf51 flat panel monitor
Good Day Tricia,
I had to pull up you owner's manual to get the spec's on your cord, so if you need the manual follow this link:
http://h10032.www1.hp.com/ctg/Manual/bph08231.pdf
Anyway after reading the spec's you need an AC-DC power supply that outputs 12volts at 3.3amps. What makes this difficult to find is the 3.3amps, most aftermarket power supply only go up to 2amps. So what's next? Well you can order directly through HP at this link:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=P4824A&HP_model=&modname=HP+vf51+15-inch+LCD+flat+panel+display&template=main&plist_sval=Power+Cord&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Cord&catsel=%3F
If you do this make sure get part 8121-0740 if you live in the states, or part 8121-0731 if you live in europe.
The only other suggestion I can give is to bring the monitor into a radioshack and see if they have a 12VDC 3.3AMP (you can get a universal with higher amperage if needed, the monitor will only draw the 3.3 it needs even if it is supplied more) and the reason I say bring it in is so they can match the size of the plug that goes into the monitor, as there are about 20 diffrent diameters's. Again the problem you may have is finding one with a high enouge amperage.
I hope this helps
Good Luck
Posted on Jul 01, 2008
SOURCE: Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Posted on Jun 03, 2009
Cant find where to plug in power cords for emachines monitor screen E15T3r model 568
AC Adapter For eMachines E15T3r 568 LCD Monitor Charger Power Supply...
As you can see from the picture the power plug is a small round connector similar to an audio input. Power Connectors
look for a connector like the DC socket in the picture
Mar 25, 2014 | MPC Computers MPC F1760I 17" FLAT PANEL...
What is the power supply for the hp 845c printer ? Thanks,
Electrical specifications NOTE: The HP Deskjet automatically accommodates the worldwide range of AC line voltages and frequencies. There is no on/off switch on the power adapter. Category Specification Input voltage 100 to 240 volt ac (VAC) (+/- 10%) Input frequency 50 to 60 Hertz (Hz) (+/- 3 Hz) Power consumption (maximum) 4 watts maximum when off
4 watts minimum when idle
45 watts maximum average printing (Printer carries the ENERGY STAR emblem)
Jul 16, 2010 | HP DeskJet 845c Printer
Where do I get lost cords for this monitor?
are you mention about the AC adapter or just power cords. For pwer cords is everywhere, but ac adapter you have to know the specification for the power input/output and size of plug since I can't tell the model on your description.
Mar 22, 2010 | Samsung SyncMaster 245BW Monitor
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Need a ac input cord
probably a computer store (should have the same hook up as a computer monitor) or radio shack just look at the input connection on the tv draw a rough picture and bring it with you or un plug your computer monitor and plug it into the tv if it fits just go to an electronic stor and ask for a monitor power cable
Apr 14, 2009 | Televison & Video
My B70A Hyundai will not power on. The green or amber light will not power on. I wanted to make sure I have the correct Plug. Are there any drivers or is it plug & Play? Thanks Lesa LesaBrown1@aol.com
This monitor is plug and play but the driver (or lack of) is not the problem.
Its either your the power supply or the monitor itself has an issue with its
internal power distribution circuitry. First make sure your power supply is
operational. The original 120V AC to 12V DC 3.3 A power supply for the
B70A had a green LED on the brick itself. You will find it on the top right
corner of the brick, on the end where the DC cord comes out (opposite
end from the AC input) If you have the AC cord plugged in the wall, the
LED should be lit. If it isn't, the brick is no good, and should be replaced.
Any 12 VDC adapter with an amperage rating of at least 1A but no greater
than 3.3 A having the same size tip (with correct polarity) should work.
If you have confirmed that the adapter IS functional and the monitor LED's
still remain off, the internal power distribution circuitry of the monitor is
damaged, probably caused by burst or leaking capacitors.
Feb 19, 2009 | Hyundai ImageQuest B70A 17" LCD Monitor
Ac power adapter requirements
From the users guide:
Power specifications
. Power consumption: 50W maximum
. Source (Input) Voltage: 100 to 240 VAC*, grounded
. Input Frequency: 50 to 60 Hz
. Current: 1A maximum
* Figures are based on using the AC adapter that came with your unit (HP part number 0950-2880)
Her's a link to the user guide:
http://h10032.www1.hp.com/ctg/Manual/bpu03123.pdf
Oct 15, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Power cords
Is it too late?
From the HP support:
Don't know if you can get an adapter, but at least you have a part #.
Dec 10, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Computers & Internet Logo
188 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
