Question about Jensen JW250 Main / Stereo Speaker
How to hook up a subwoofer to my computer?
Hi there,I was wondering if I could hook up a subwoofer to my pc without an amp. I have the subwoofer, but it needs the two cables that you stick inside of it. Black and green. Like, it's not a subwoofer that you just buy and plug into your computer.
It's one of the ones where you have to get a wire, and cut off the end of it, and strip it down to the metal part, or the copper (Whichever) And lift a little lever to stick the cable inside of the subwoofer.
When other sound systems, all of the speakers hook up to the woofer, and the subwoofer has the power cable, and the green, pink, and black cables that plug into the back of your pc.
This system came with a dvd player, it's a 5.1 system, but all cables are the stripped down ones that hook up into the dvd player seperately.
I was hoping if there was some sort of pieces to convert it into a normal audio cable so I can plug it into the back of my pc?
Thank you for your help (p.s, I just want the subwoofer plugged into my pc, I already have a 5.1, 2.1, and a 2.0 hooked up. I only want the extra woofer)
  • Craig Bailey Jan 26, 2009
    I bought a Hitachi Model HTS5 Subwoofer and I'm trying to hook it up to my Dell PC all it has is one female jack just like the jack for the speaker on the back of my PC and then it has a left and right female jack audio in put. and then it has 2 front speaker out puts the strip wire type. My computer is a Dell 2400 Series. Looking for better sound can any one help me. Craig.
  • j_maher3 Feb 16, 2009
    yes the same problem with a dell e520 i have a hifi Yamaha sub woofer have the right connection lead
    where the confusion starts is
    one can one do it i have two options on the sound card the first is the five speaker options. To me this is not clear because on the back of the Dell there is 6 female sockets the green one which is the normal one for sound in the middle and orange one underneath and another orange one to the right of the green left of the green in turquoise left and right underneath are green and Black. I assume that one use the two centre holes above and below am i right? if so im getting no sound to the Yamaha
    Do we have to reboot the computer each time we try a sound socket.
I to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Posted on May 13, 2009
Connecting mtx fex10a-tn subwoofer to sony xav601bt
You should always wire your amp directly to your battery. and an inline fuse of about 100 amp. about 3-5 feet from the battery.
Dec 15, 2012 | MTX Audio Thunderform FEX10A-TN Black,...
Hi, I'm wondering what the (blue/white) P.Cntr wire hooks up to??
it's a power control line, it comes on when the amp does and would go to the REMOTE input on a power amp.
Mar 07, 2011 | Car Audio & Video
I am trying to hook up an after market subwoofer and amp to my 2003 hyundai tiburon gt v6, but everything is hooked up right and the amp has power but it doesnt work. so I am wondering since the car came...
How have you connected the amp to your head unit is it with a dedicated sub source from the head unit or have you connected the speaker outputs to it ?
Dec 09, 2017 | Car Audio & Video
Is it possible to hook the infinity bu-1 subwoofer to a home theater system where the subwoofer output is straight power say it"s like 25 watts coming out of that one channel and before the original...
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
Jul 21, 2010 | Infinity BU-1 Speaker
Factory subwoofer 2005 subaru, the after market head unit I got dont have the connectors for it.
try to get a "speakerwire to rca cable" connector. hook it into your back speaker wire and run your amp off of that. then hook the sub up to the amp as usual. without an amp, just splice into your closest speaker wire
Feb 23, 2010 | Car Audio & Video
I have a 12" subwoofer and i was wanting to know how to hook it up with out a amp or if you can even do that
They need alot of power to get sound out of them. If you hooked it up straight to the radio without an amp, you would barely hear it.
Sep 08, 2009 | Car Audio & Video
Subs for buick lesabre
yes just purchace an amp that has speaker level line in....then just wire it directly to your back dash speakers,,,,
Mar 29, 2009 | 2000 Buick LeSabre
Sony sa-w305
Hi bob,
yes I have the active subwoofer book, SA-W305 1998
If you let me have an e-mail address, I will scan and send you copies (8 pages) regards Brian.
P.S. I have been using the unit on its own, just connected to my new tv, and the bass improvment is fantastic.
I had to have the amp TA-VE150 repaired,by having the IC joints resoldered, due to overheating.
Aug 17, 2008 | Sony SA-W305 Subwoofer
Need to know
I'm assuming that you have an amp that you are installing these to. Its always tricky installing subs of different impedances. Do you have the model number of the amp that you are hooking them up to.
Most likely if you have a 2 channel amp, you would connect one sub to each channel as most amps can handle a 2ohm load in stereo, but don't bridge the amp with these two subwoofers without specific instruction from someone with experience as you will most likely overlad the amp. If you can be more specific with your set-up I'd be able to assist you more.
Mar 30, 2008 | Alpine Type-R SWR-1042D Car Subwoofer
Jensen JW250 Main / Stereo Speaker Logo
4,297 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
