Question about GE JE2160 Microwave Oven
I have a ge microwave # JES1358WK. i think the 15 amp ceramic fuse has blown. Question is : would like to know how is the best way to open the case. are there any free online exploded views I could get an idea or some guidance as to disassemble the case mentioned above. thanks, Bob
  • GE Master
  • 9,086 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In many models there is a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting, testing, and locating components.
Posted on Jan 12, 2009
I have a microwave JVM3670SK06  ge what amp fuse does it use
I found a good site to find parts for the microwave. It has the fuse for $7. GE WB27X10388 Line Fuse PartSelect
Here is another search form different sellers.
WB27X0007 GE Microwave Ceramic Fuse Replacement
The fuse info
Specifications:
  • 250 Volt.
  • 15 Amp.
  • Type: Fast Blow.
  • Approx. 1.25"L.
Oct 18, 2015 | GE Microwave Ovens
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Spacemaker died while operating with nothing inside
your ceramic internal fuse blew, you can get them at most hardware stores its either a 15 or 20 amp ceramic fuse, then if this blows again chk your h.v. capacitor,h.v. diode,or the magnetron tube for defects
Oct 27, 2009 | GE Profile Spacemaker JVM1871 Microwave...
Kenmore Spacemaker Fuse Blown
its either a 10-15-or20 ceramic fuse and its marked on the side of the fuse or take it to the hardware store they have this type of special fuse.and they can locate the rating for you
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Is there a fuse or circut breaker in the spacemaker?
yes a ceramic 15 or 20 amp fuse replace only with ceramic fuse sold at most hardware stores,its under outer cover its a 1" long by 1/8" dia white glass tube
Sep 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ok , I replaced the fuse checked all connections and checked plug for power ! Still my lg lmv1630st will not show any power at all . What gives?
by replacing the fuse you meant the house circuit fuse or the microwaves internal fuse? and by conncetions your talking the internal wiring inside the case of the unit or wiring from the plug? if not its your 15 or 20 amp ceramic fuse inside the unit,if thats blown replace,but chk h.v.diode,v.v. cap,triac,control board, mis-adjusted interlock safety door switch,and lastly the mag could be defective
Aug 15, 2009 | LG Over-the-Range Microwave
Microwave died
your microwaves internal ceramic safety fuse is blown most hdwg stores carry them they're a 15 or 20 amp fuse,dont replace w/any other type of fuse,but first find out why oven blew the fuse
Aug 13, 2009 | Whirlpool MH7140XF Microwave Oven
GE Spacemaker Microwave Blown Fuse replaced still no power
If you measure across the varistor leads with it still in the circuit, you should measure around 100-300 ohms, which is the DC resistance of the primary of the low voltage transformer.
If you read infinity / open the primary of the low voltage transformer is bad.
If the varistor is bad, it will be shorted and usually it will be cracked or split. This is a much simpler way to test the varistor.
Have you checked the magnetron thermal cutout (TCO) (or thermostat if so equipped) and the oven TCO? These are the leading causes of a dead GE when the fuse is okay.
You didn't mention the model number. What is it?
Please reply back here if you still need help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Microwave Ovens
GE JE2160 Microwave Oven Logo
280 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
