Question about Vizio L37 Television
NO RED TV IS GREAT BUT NO REDS THE DETROIT RED WINGS ARE NOW THE GREEN WINGS. 37 IN VIZIO VW37L 40A
  • samcortina Jan 25, 2009
    I have the same problem but for the satellite input it only shows shades of red, and when i attempt to play a DVD from input 1 or 2 then the screen is only in shades of Green.  What in the world can I do?
Thanks to kml39. My problem was either the cables or the component input, but I put a new set of cables left by the cable guy to the other component lines into the TV and it worked. I now have red again. This has been screwed up for quite a while, so I'm happy to have it fixed.
Posted on Jan 24, 2009
    Problem Solver:
  • 16 Answers
As a cable tech I have seen this before, you either have the cables from the sourse plugged into the wrong color or the cable is bad itself. get a new cable, you can check the tv by connecting a DVD player to it, if the color is fine on that then you know you might have a connection problem. if its bad on the DVD, then you may have a tv problem. Most TV's have more than one RGB input, try changing inputs, and double check to make sure the red line is in, If you are using an HDMI cable then all you can do is call a good tv repair man and hope your waranty is stil valid.
Posted on Jan 18, 2009
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
How do i connect internet to a vizio vw37L tv
Yes, if after you checked all the connections source then your main board is defective. The Wifi/B in the tv could be on the main board or close to the main board but have a tech come out and replace it.
Feb 11, 2013 | Vizio VW37L 37 in. LCD TV
I have a Vizio 37" TV (VW37L HDTV 10A) bought in
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ ///
Sep 03, 2017 | Vizio VW37L 37 in. LCD TV
Lost my remote for my vizio 37 inch tv
buy a replacement remote find code in code book with tv u have with remote and manuel.
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
42 inch vizio has picture (direct tv) but no sound. Tv is not on mute.
Did you check the RCA AV Cables? The ones with the red, white yellow?
What is the connection you have from Direct TV box to your TV. You might want to start on that.
It might probably as well related to any of the remote controls settings. Either of the Direct TV control or TV Control.
1. Check the cables
2. Check if there is any function on the Direct TV remote that will turn off the sound
3. CHeck the Vizio TV Menu Settings.
4. Try with other component such as DVD to discard the possibility of malfunctioning VIZIO Speakers.
Vizio offer a good customer service if still under warranty.
God Bless You!!
I have a mfg date 2007 Vizio VW37L HDTV10A turned on and there is sound but not picture
This can happen. are the lights on? if not, it most likely id the power source inside the tv itself. make sure your wall outlets are working properly as well, but if they are, then you want to get you tv fixed. this can be a relatively low cost repair, but shop around
Apr 18, 2010 | Vizio VW37L 37 in. LCD TV
Vizio vw37l tv with a lost remote. i have a panasonic universal one is it possible to program it?
Try 1-800-Remotes Factory original.Buy an exact remote.Finding unversial remote codes like pulling teeth i'm telling u.
Jan 19, 2010 | Vizio VW37L 37 in. LCD TV
I have a Vizio LCD TV and lost the remote that came with the TV. I have a one for all universal remote, its a URC-4640BOO . I am looking for a code to program the TV
see the vizio website, click on the "support" tab and look in the FAQ regarding programming non-Vizio remotes for Vizio products (#6 in FAQ list), they have all 3, 4 and 5 digit codes there
www.vizio.com/support
Dec 11, 2009 | Vizio VW37L 37 in. LCD TV
The TV has red and green lines, I touched the
you willl need an LCD panel replaced the buzzing sound you hear is the broken floresent bulbs arching
Nov 30, 2009 | Vizio VW37L 37 in. LCD TV
Vizio VW37L
720p & 1080P are what you want, the vizio has a higher repair rate than most, check out the toshiba or the samsung
Jul 17, 2009 | Vizio VW37L 37 in. LCD TV
Vizio L37 Television Logo
128 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
