Question about Emerson SpongeBob SquarePants TV
Whats Wrong with the Passwrd.
I set a password for the parental control in the menu but not on the DVD menu and I thought that they were the same password but every time I enter in the password is says "Wrong Password". I unblocked everything and turned off the paretal control but it still won't play my DVD with out the password. Whats wrong?
  • 1 more comment
  • babyalex04 Nov 05, 2007
    i tried to put a movie on for my son and it kept asking me for a password so i changed all the parental settings and on the top left coroner of the tv it keeps asking for a password so i put my password in and it says incorrect password
  • jandnik Nov 24, 2007
    I have the same problem. i never even set up a password but i cant watch anything PG or higher.
  • Joy Juarez
    Joy Juarez Dec 30, 2007
    I have already set a password when we set up the tv and now it will not work. I have already turned eveything off and it will still not work. Everything I try it says wrong password.
  • 203 Answers
It sounds as though someone set a password without your knowledge. Take your model number and go to Funai's website to look up the owners manual http://www.emersonaudiovideo.com/support/manuals.aspx
Posted on Jun 09, 2007
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
I inserted a DVD and the words parental control limit comes up on the screen. It's rated R but I have received many dvds from Netflix rated R which played with no problem. There is a bar with a picture...
If you are able to, go into the setup menu, select 'parental control', check the rating (8 is restricted - 1 is no restriction), and 'unlock' (if you have not set a password) then exit the setup. This should solve the issue for all future discs (parental lock is a pointless feature in DVD players, as often, owners set passwords, only to forget them later, so they cannot undo this function).
* This is for a Zenith XVB442 DVD/VCR combo, but essentially a similar setup *
If you forget your 4-digit password
If you forget your password, to clear the current password
follow the procedure below.
1 Press SETUP to display the setup menu.
2 Enter the 6-digit number 210499 and then press
ENTER.
The 4-digit password is cleared.
3 Enter a new password then OK.
I do not recommend setting parental lock passwords in DVD players, but you may not need to do this, so the above is a 'just in case'.
Apr 19, 2011 | Zenith Televison & Video
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
Unlock instructions for Toshiba dr570 DVD
Hello
Turn on your DVD player and television. Select the appropriate input source for your DVD player on your television.
Press the "Setup" button on your DVD player's remote control to display the main menu.
Navigate to the "Rating" menu option using the "Down" button on your remote control. Choose the "Parental Control" item by pressing the "Right" arrow button, followed by "Enter."
Enter the parental control access password using the numerical pad on your remote control, followed by the "Enter" button. If you did not previously setup a unique password, enter "8888" when prompted for the password.
Press the "Enter" button to display the parental control rating menu. Select the "8: Adult" menu selection by pressing the "Up" or "Down" directional buttons on your remote control, followed by "Enter." Press the "Open/Close" button on the front of the DVD player to complete the process.
Nov 21, 2010 | Toshiba DR570 DVD Recorder
Parental lock
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
Apr 27, 2009 | KLH KD1220 DVD Player
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Changing parental control
Start the PS2 up and load the DVD. When it shows the Parental screen select YES. When the Password box pops up. Press the Select button on the controller. Type in 7444. Then your password is reset. It will ask you to enter another password. Do that twice. Allow the movie to start. When it gets going pause the movie, Press the Select button on your controller again. The DVD menu pops up. highlight SETUP. When that setup screen appears go to the 3rd icon from the left. Press X. Then highlight Parental Code. Set the parental lockout level to OFF.
Nov 20, 2007 | Sony PlayStation 2 (PS2) Console
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Parental levels
Put in a DVD, and press select button to go to PS2 DVD menu.  highlight setup menu. Press X.  go to settings I think, and paretal control is there.  Use password 7444.   Usually everyone sets the password to 0000.  Then when you go into the parental settings, turn the level value to OFF
Oct 11, 2007 | Sony PlayStation 2 (PS2) Console
Dvd parental controls
With a DVD disc inserted in your PS2, press the Select button to bring up the on-screen Control Panel. Press the X button to select the Setup icon. Use the directional pad to reach the "Custom Setup" menu, and press the X button. Move to "Parental Control" and select with the X button. A window will appear asking you to enter a four-digit password. Enter your choice of password using the number buttons that appear then enter it again for confirmation. You're now able to set the Parental Control level using the "Region" and "Level" options, and change your password
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Emerson SpongeBob SquarePants TV Logo
119 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
