Question about Miele Touchtronic W1113 Washing Machine
My 30 year old GE compact washer won't spin
I can't believe it can't be fixed. This is a GE Model WWP 1150 compact clothes washer. It tries to spin, but is anemic and eventually quits trying. I checked the belt and it's tight. The problem might be in the controls. I'd replace it, but I can't find another washer that will fit in the same space. It's only 21 inches deep. What are the possibilities?
  • 640 Answers
Easy,,avanti.com..
Posted on Jan 12, 2009
GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Jul 22, 2009 | GE WSXH208A Front Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
It washes but will not spin
After having a similar problem and looking all over this website, I found a lot of answers from "experts" saying that the washer should be replaced, or replace the motor, etc.
I just found this at the GE website, and it cured the problem in less than 2 minutes. I'm no expert, but I'd at least recommend trying this.
http://www.geappliances.com/search/fast/infobase/10013033.htm
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Can't get agitator off of GE spacemaker model WWP 1180G
There is a bolt, ok. Remove the bolt and lift the agitator by reaching underneath it with both hands on each side and pull it up. If it seems really stuck, apply some WD40 and let it soak a bit before trying to pull it again.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Won't spin with clothes in it.
sounds like a tired washer, it may be cheaper to purchase another for a couple hundred bucks
Jun 14, 2008 | GE WBSR3140DW Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Old GE Washer WNSR2100T8WW will not pump out water nor spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 12, 2007 | GE WJSR2070B Top Load Washer
Miele Touchtronic W1113 Washing Machine Logo
209 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
