Question about Toshiba Satellite P15-S479 Notebook
Mouse pointer stalls
Toshiba Satellite P15 running off battery, the pointer works well. Once the laptop is on AC power the mouse pointer sticks on the screen or "stalls". I run my fingers across the touch pad several times and eventually it catches up
  • Anonymous Jan 24, 2009
    same with my Satellite P15-S420. Just replaced the DC input..same issue still
Won't startup in normal windows configuration stalls and get blue screen with mouse pointer
Have you test it with a good working hard drive? Possibly the hard drive is dying.
Feb 27, 2014 | Toshiba Satellite A505-S6965 (4400 mAh)
My mouse don't work and my usb input don't work either
go to device manager,Universal Serial Bus controllers and see if there's a device with "?" sign on it,if there are,uninstall the device and restart your computer
Aug 25, 2012 | Toshiba Satellite P15-S420 Notebook
How can I disable the pinch zoom on my Toshiba Satellite L675D-S7107? When I'm scrolling up or down, sometimes the pointer turns into a black cross with arrows at each end and the text becomes resized. ...
Try going to Control Panel - Hardware and sound - mouse. Once you have the menu for the mouse open, go to device settings. Click settings, and all of the advanced controls for the functions of your mouse pad can be found there.
Mar 12, 2011 | Toshiba Satellite L675D-S7107 17.3" Laptop...
While charging my laptop , mouse pointer cant work and while it is running on batteries mouse pointer works
hi
remove the battery from your notebook -- use the Ac adapter only
will the mouse pointer work ? are you using an attched wirelss mouse or the palmrest pointer ?
let me know what OS you use -- and if its mouse you use, what model ?
look forward to helping you resolve the issue !
Nov 03, 2010 | Dell Inspiron 1525 Notebook
How do you adjust the touchpad on the Satellite L505 Toshiba?
Hi, to adjust the touchpad settings for your Toshiba L505 kindly follow the Step by Step intruction guide on this link,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Mouse+pointer+jumps+around+as+you+type
You will see several search results, just click the topmost result which says "Mouse pointer jumps around as you type". You will then see a detailed guide on how to adjust touchpad settings. Hope this works for you.
Oct 30, 2010 | Toshiba Satellite L505ES5018 Laptop
Toshiba P15 S479 Laptop
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Nov 04, 2008 | Toshiba Satellite P15-S479 Notebook
Lapptop touch pad not responsive
hii srm-mom ....
see jst fallow wat i m sayin....
go to start option>control panel>printer n other hardware>mouse
here u can set urs mouse speed n urs mouse pointer....
if u r not able to see ny mouse pointer choose diffrent pointer..
if irs mouse speed is slow u can increase it also...
try dis tell me.....
dis settting for windows xp nly....
if ur usin vista same as it but sm diffrent..
thanks...
Jun 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Maximizes & minimizes screen while scrolling or using pointer on Vista
change mouse out buy replacemnt goes under the plastic housing not to bad to change 20 bucks on ebay
Feb 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite P15-S479 Notebook Logo
191 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
