Question about LG 42PX5D 42 in. Plasma HDTV
Red dots on my LG 42PX5D
I have red dots on the black on the top 1/3 of the screen. I have a monster surge guard AV800 and a monster HDMI 1000EX attached to a skyHD box.
The problem seems to be intermittent, but it does happen a lot, which makes me think it's some kind of interference, from an outside source possibly... but what? Where would I begin to find out if this is the case. Ofcom maybe?
Or if someone could shed any light on my issue I'd be very grateful, thank you.
  • ultravilet Jan 14, 2009
    Sorry I didn't understand that at all. Thanks anyway.
  • brijac Feb 27, 2009
    My 42PX5D has a simlar problem. On a no signal screen the bottom half shows a snowy red cloud also on very dark scene's the blacks have the same problem. If it is a dark still scene the red slowly decays over a few seconds and dissappears till there's movement and back it comes.
    Thanks for any help you can offer.
  • 50 Answers
Hello, you do not need to replace any of the sustain boards in your TV to fix the problem you are having. All you need to do is remove the back cover and make an adjustment to the Y sustain board. You will need to adjust the set_up & or the set_down! If you would like to do the adjustments to your TV please feel free to give me a call or message me. Ask for Dave! 1-503-432-9904 or message me @ You will need to remove the stand & the back cover. Then put the stand back on the TV so that you are able to set the TV in the up right position with the back cover off! Then you'll need to hook the TV up to a DVD player so that you are able to pause the picture while you are doing the adjustment to the Y sus! Do not adjust any other adjuster on the Y sus other then the SET_UP or the SET_DOWN. In order to identify the correct adjusters on the Ysus just look on the board and it should say SET_UP & SET_DOWN next to the correct adjusters. If you need more help please feel free to give me a call or message me!
Posted on Feb 08, 2009
  • 1,694 Answers
Y - sustain & z - sustain PCB's have adjustments to minimize
problem, but replacing boyh boards & then adjust is best......
Posted on Jan 13, 2009
  • Vista Electronics Jan 14, 2009
    Have a tech replace both sustain circuit boards........T.
My ill dads Vizio VO320E showed classic symptoms of lightening damage so we purchased a new main board. Now the screen lights up but is showing pink and yellow horizontal stripes and some vertical sha
Mr. John either one of two things from start u have done right this is a common thing on flat sets hooked to Direct boxes by HDMI having surges come from box to set. The main board usually needs replacing, so either u received a bad board or u have multiple issues and possibly the T-CON board got surged from main board. This board is located above main and power in center at very top of screen. This will cause symptom that u are describing. Hope this helps.
Dec 08, 2014 | Vizio VO320E LCD TV
How do I connect to set top box, The set top box is connected to the TV via HDMI.
Your set top box should have secondary RCA outputs along with the HDMI. run another RCA standard yellow- red- white cable to the Onkyo's video 1 input. Use Monster cables for best performance..
Mar 20, 2011 | Onkyo TX-SR502 Receiver
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
Nov 06, 2010 | LG Televison & Video
Killed by lightning, have power, no picture...
The warranty does not cover lightning, check if your insurance covers it.
A lightning strike on such panel ( HDMI ) is very difficult to repair and if not impossible.The HDMI connector is hooked to the ground of the TV set so everything could be damaged.
My advice is not to repair.
Aug 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Ive just moved to a house with sky all ready and have not got a clue how to set the thing up. I have a 50in PS-50Q96HD Samsung HDTV Plasma. I have the sky cable and the normal tv cable, what goes were...
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
Hope this has answered your questions
Little Dish Fitter
Feb 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Small dots all over screen
This happened to me right before the one red light issue arrived
Aug 26, 2008 | Microsoft Xbox 360 Console
Red color slide on left side of 43UWX10B
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
Good luck, big IRISH.
Aug 05, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Screen black after big storm...
The set has sound and no picture.If you the SSB could be the issue but the tiny red dots on a black screen will need the panle replaced also. There is a way troble shooting can be done to determine if you will need the SSB or the SSB and the panel.
May 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
Ps3 sound problem
PS3 is The amazing device by sony but it has some common problems like sound, but no picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Oct 10, 2007 | Sony Playstation 3 (PS3) Console
LG 42PX5D 42 in. Plasma HDTV Logo
962 people viewed this question
Computer Repairing
Computer Repairing
